Epson Thermal M244A
All numbers and letters are not printing. Left side of receipt is worse than right side. Thermal heads have been cleaned in accordance to user's manual. Do I need a new printer or can it be repaired?
3 Suggested Answers
SOURCE: Light printing on receipt
I was able to darken the print resolution with the help of a software company I pay each month for technical solutions. They had me take a plate off of the bottom of the printer and change a very small switch that if I had not been directed exactly how to do it I would have never tried it. thanks
Posted on Nov 26, 2008
  • 5339 Answers
SOURCE: i need a user manual for a Epson TM-T88II POS Thermal Receipt Printer M129B
Epson has the manual for the TM-T88II here: http://content.epson.de/fileadmin/content/files/RSD/AnwenderhandPDFs/DE/TM-T88II_user_e.pdf .
I hope this helps.
Posted on Feb 01, 2012
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
I have a question about POS Epson receipt printer TM-88-T. When the receipt prints out, the thermal text on only the left side is faded. Does anyone have any idea how to fix this?? Thanks
Its nothing, due to the misalign of the head. open top cover. pull out paper. insert you finger through that open toward the head push the head downwards. Replace the paper and take printout.
Nov 04, 2013 | Epson TM 88III Receipt Printer
The problem I'm having is that the printer prints partially when printing receipts. Most of the numbers are un-readable.
You could try cleaning the thermal head (the black shiny thing inside the lid that does the printing) with some isopropyl alcohol and a cotton bud. Failing that, it might need a thermal head replacement. Or you could also try printing in a larger font (if this is possible in your pos system).
Mar 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Fax problem
left side is printing and right is not printing.first clean thermal head after this check cover locks may bi right side cover lock is broken .just press from right side and make a copy .otherwise replace thermal head .MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FP80 Plain Paper Thermal...
Nov 24, 2008 | Epson TM-H60000II Thermal Printer
Epson printer troubleshooting
hi there, you do have a ribbon cable problem, the white strip wire which is connected to the head of the printer. repalce the ribbon head cable and add some cleaning and lubrication on your printer machine. ty
Dec 23, 2007 | Epson LX-300 Matrix Printer
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
1,250 people viewed this question
k24674
jasbo
jasbo
