Magnavox 26MF231D 37 inch HDTV - green light blinks when attempting to power up, then red light flashes off and on from inside the rear casing (visible thru the plastic grating) TV will not power on.
abhishek33
  • 1239 Answers
SOURCE: MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Posted on Jan 07, 2009
SOURCE: Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Posted on Feb 06, 2009
SOURCE: 50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Posted on Mar 23, 2009
  • 86 Answers
SOURCE: Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
Posted on Mar 26, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
I have a 26mf231 Magnavox 26 inch tv. The screen on the tv just flashes over and over. Never powers up. I took out the power board and all the capacitors look good. Thanks in advance
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | Philips 26MF231D 26 in. LCD Television
26MF231D 37 Inch. Green Blinking Light - will not power on.
These blinks are fault indications, and are called blinking codes. For Philips brand TVs, we cannot count these blink directly; there is an other way to count these, and should be converted to error codes numbers. If you wish to get more details about how to count these blinks to Philips brand TVs, check the link sited here. After converting these blinks to error codes, you can get an idea about the faulty circuit stage inside the TV. Check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 15, 2013 | Philips 26MF231D 26 in. LCD Television
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Sharp 37 inch aqous tv power button blinking red
If the blinking light seems to be blinking in a pattern, then it is an error code. The end result in any case, is the main power supply is not functioning properly, or the backlight power supply has a problem.
Nov 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
