Question about Tokina AF 100mm f/2.8 Macro Lens for Minolta
Tokina f2.8 100mm macro. setting apature and shutter speed. little manual with lens not very informative.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Tokina Master
  • 102,366 Answers
Turn the aperture ring to the smallest aperture (largest f/number) and lock it there. Set the aperture and shutter speed on the camera body. You didn't specify which camera you're using, so I'm afraid I can't give you details there.
Posted on Jan 20, 2010
2 Suggested Answers
  • 102366 Answers
SOURCE: tokina f2.8 100mm macro nikon mount. setting
You will find all the information in the camera manual, not the lens manual.
I have just purchased a Tamron 35-70 3.5 CF MACRO BBar MC Nikon fit lens. Are there any special settings/requirements when using the lens for macro photography. Thanks.
This is a macro lens, and I can't find it has an auto focus nor can I find if it has a chip, or even any electrical connection. The sharpness though should be good.
When you are using a non chip lens on a Nikon, you only can use it in manual. So you have to put the main dial to M. Then you have to focus manual and just take a shot. the result will be to dark or to light, unless you already knew hoe much light you have and dialled the aperture and shutter time in correct.
For macro you want a large aperture number, to have as much sharpness (large depth of field) so the best thing is to choose f 8 or 11 and turn down the speed till you have a good light picture.
I found a forum about this lens, but they did not say a thing about the specs.
Tamron Adaptall 2 35 70mm F3 5 CF Macro 17A
Check some results here:
Tamron 35 70mm 3 5 17A on the GH2
Jan 23, 2015 | Nikon Cameras
Taking pictures with x3 telephoto lens
may be there is some problem with your shutter speed and lens
Jun 18, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
Photos to dark
The aperture and shutter speed setting depends on the amount of light and on the effect you want to achieve. For any given lighting situation there are many possible aperture/shutter speed settings that are all equally valid. However, the aperture also determines the depth of field, and the shutter speed can either freeze action or allow it to blur. Only you as the photographer can decide which of those valid exposure settings best conveys your vision.
As to how to determine the proper exposure, there are several possibilities. One is to use a light meter. If you don't have a separate light meter, you can use another lens and meter through it. It may not give you exactly the same field of view, but it should get you into the ballpark. Then there's the "sunny-16 rule." This says that under a bright sun, the proper exposure is f/16 with a shutter speed equivalent to 1 over the ISO. Of course this is just a starting point, and you can adjust the aperture/shutter speed to achieve the desired result.
I suggest you visit your local library. They should have introductory books on photography which will explain all this in depth.
Mar 06, 2012 | Tokina f/NIKON- 80-200/4.5-5.6 SZX Zoom...
Unsharp pictures when using the leica macro 90mm 4:0 lens as a telephoto lens
Besides any problems with the focus mechanism which should be fairly obvious, your shutter speed may be too slow. A slow shutter speed can be set manually or caused automatically when using a smaller aperture in lower light settings, the camera compensates by opening up the shutter. Try testing your lens out in bright scenes with the aperture open. Another problem is with manual lenses at low apertures. It can be difficult to manually focus at just the right point because shooting around f.4 with a longer barrel lens leads to a very shallow depth of field. To compensate, try a smaller aperture or take a few photos of a subject while adjusting your focus to get the "money shot." If all the above fails make sure to double check your sensor and lens are clean, a greasy or dirty lens will always lead to less crisp photos.
Feb 26, 2011 | Leica 90mm f/4 Macro-Elmar M Manual Focus...
The !AE error messsage and a yellow !camera image appears on the camera screen and pictures are horribly blurry. How can this be fixed?
if this is a slr camera ensure the lens is fitted correctly or that the connectors on the lens and body of camera are clean.
also try changing setting out of AE "apature priority" to another setting such as auto, the indication could mean that the place where the photo is being taken is too dark and that the apature setting for the speed set is too small for a decent image. and the apatures needs to be open further or the shutter speed needs to be slower or the IOS/ASA needs to be raised. to stop bluring at slower shutter speeds or in dark areas it is advised to use a tripod or other sability device.
I hope this was useful.
Jan 24, 2011 | Cameras
Tokina f2.8 100mm macro nikon mount. setting apature and shutter speed. little manual with lens not very informative.
Apr 24, 2009 | Tokina AF 100mm f/2.8 Macro Lens for...
How to change my apature...what button?
Use Av mode to change the aperture.
If you want to do this in Manual, where you rotate the wheel to change the shutter timing, press the Av button on back whilst rotating the wheel to change the aperture.
Feb 14, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Changing lens
Your Nikon is a SLR which stands for single lens reflex. The reflex part is the way the mirror that lets you look through the lens to frame the picture flips up to let the light go straight to the film. You can change the lens half way through the film roll because the mirror is down while you change the film and blocks light from getting to the film, just as it blocks the light until you push the shutter button. Have fun with your 'new' camera! I use an even older style Nikon FE2. I like my Nikon 55mm macro lens but your newer camera takes autofocus lenses so you'll need advice from someone else for that.
Oct 01, 2008 | Nikon F65 35mm SLR Camera
Canon Power shot 570 IS problem
Check to see if your camera is in Macro mode. This may cause blur. Also hit your function/set button to see if it is in digital macro mode.
Make sure your lens is clean.
Make sure you are set to automatic mode and zoomed all the way out. There are several things that may cause blur, the most of which is camera shake. Make sure your Image Stabilization is turned on. If it is, you will see a little hand in the bottom right corner of the LCD screen.
If it's not on, turn it on in the setup (tools) menu.
If your shutter speed is slow, this will cause image blur, but in auto mode, you won't have to worry about the shutter speed, it will be set automatically.
Hope this helps.
Apr 22, 2008 | Canon PowerShot A540 Digital Camera
Tokina AF 100mm f/2.8 Macro Lens for Minolta Logo
213 people viewed this question
Top Tokina Cameras Experts
Steve
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
