Question about Homelite Zama Rb3 Carb Kit 330 Chainsaw Chain Saw
Where do the 2 fuel lines in homelite 330 go - Homelite Zama Rb3 Carb Kit 330 Chainsaw Chain Saw
4 Suggested Answers
  • 4088 Answers
SOURCE: hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 15, 2010
  • 9 Answers
SOURCE: need to know the fuel and oil mix on a homelite
The fuel, oil mix for homelite chinsaws is 32:1. Hope this helps.
Posted on Sep 27, 2010
  • 130 Answers
SOURCE: Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Posted on Feb 20, 2011
What is the fuel mix for a homelite 330 chainsaw?
Two pints of oil to 2 1/2 gallons of gas...or 1 pint to 1.3 gallons of gas.
Jul 30, 2014 | Homelite Garden
Exact mixture for Dynamac DY51 chainsaw?
need a fuel line diagram for a homelite 330 chain saw
Dec 02, 2013 | Homelite Garden
Homelite chainsaw fuel line diagram
Oct 05, 2013 | Homelite Garden
Fuel line routing
i took the homelite 330apart in doing so the lines broke no problem i needed to replace them any way so now im confused to where they all go
Oct 01, 2013 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Need to know the fuel and oil mix on a homelite 330 chainsaw
Sep 26, 2010 | Homelite ZR10926 16" Chain Saw
Hi how to tune homelite 330 chain saw carby, idle
May 09, 2010 | Homelite ZR10926 16" Chain Saw
Rebilted carb.replaced fuel line start if u put gas in carb will not run old saw but comp. is good. rebilt befor. with no problem 330 homelight.one line go to the fuel tank where do the other line go to...
Your fuel line may be pinched off where is routes to the carb.
Check and make sure that the vent in the fuel cap is clear so you are getting air in the tank
Spark to the plug?
Second line to body of saw is the vacuum from the lower 1/2 of cylinder
Mar 08, 2010 | Homelite ZR10926 16" Chain Saw
Homelite Zama Rb3 Carb Kit  330 Chainsaw Chain Saw Logo
22 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
