Question about HP Pavilion N5415 Notebook
Removing the cover to get to the hard drive on a pavilion n5415
I just need to know the steps to remove the cover so i can replace the hard drive with a biger one.
    Problem Solver:
  • 13 Answers
Flip your computer over, use a screw driver to get the top off
suggestion- wear surgical gloves--best not to touch the hard drive
on a laptop, you sometimes cant expand the hd because the box is too small
Posted on Apr 24, 2009
Remove hard drive from hp a1423w
I hope this helps:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph03429&lc=en
Above are the step by step on how to remove the cover and then the hard drive.
Aug 10, 2012 | HP Pavilion a1423w PC Desktop
How to locate hard drive hp pavilion n5415 ....thx in andavce
remove the large panel on the bottom of your pc (usually bottom right corner) the hard drive is under there.
Feb 06, 2011 | HP Pavilion N5415 Notebook
Replace dvd in HP pavilion n5415
Flip it over so the bottom side is on top. There is one screw with a little picture next to it. Unscrew it and pull the drive out.
Jul 09, 2010 | Toshiba Satellite A135-S2276 Notebook
Remove hard drive
Step 1: Use the following steps to open the case:
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
  5. On some cases, it may be necessary to remove the front of the PC so that you can remove the drive cage. If so, press in on the tabs that retain the front cover, there should three to four on each side of the cover and gently pull forward. It helps to have a friend help with this process. Carefully detach any cables that may also be attached to the front cover.c00376513.gif
Step 2: Disconnecting the cables
    If you are replacing a drive, use this section to find and unplug the IDE/Serial ATA or power cables.If you are adding an additional drive and the empty bay is part of a removable drive cage, use this section to find and unplug the cable to make the drive cage removal easier.If you are adding an additional drive into an empty drive bay on the chassis, skip this section and go to Step 5 .
  1. Find the hard drive. The hard drive usually sits under the CD and DVD drives and has a thin flat ribbon cable.
  2. Disconnect the IDE or Serial ATA cable and the power cable from the back of the drive. remember where each cable goes. IDE Serial ATA c00378000.jpg c00378001.jpg
c00564485.jpg Step 3: Removing the drive cage On many HP and Compaq PCs, drives are attached to drive cages. Often, the installation and removal instruction for the cages are located next to the drive cage or on the side panel. The following images are some examples of the types of drive cages that come on HP and Compaq PCs. For more detailed information information about a particular chassis, refer to the Hardware and Servicing guide or User Guide for your particular model of PC. Drive cage examples c00378002.gif c00378003.gif c00378004.gif c00378005.gif Step 4: Removing the drive
    If the drive is attached to the chassis or drive cage with screws, remove the screws and slide the drive out.If the drive is retained by a plastic latching system, lift the latch to slide the drive out.Set the old drive aside. If the drive is to be re-used, place it in an ESD safe container for storage.
Jun 30, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
How do you replace a hard drive in a HP Pavilion -Model 8674D?
The instructions for removing the back cover or front cover might be in the Owner's manual. You need to remove the access panel and once you remove it just uncrew the old hard drive and install the new one and recoonect the wires.
May 25, 2010 | HP Pavilion (PN153AAR) PC Desktop
How to remove my hard drive hp pavilion dv1000
Please follow these steps.
1) First of all, first unplug the power and also remove the battery.
2) Flip over your laptop. Make sure that when you are looking at the laptop bottom that the battery slot is located on the top portion.
3) On the lower right portion is the hard drive bay. You would notice two small screws on its left side. Loosen them up.
4) Lift the left side up and swing it to the right and remove the cover.
5) You would then notice a plastic or mylar tab on the left side lift the hard drive using that tab.
6) Slide the hard drive towards the left and it will be removed from the hard drive bay.
And that is it. That is how you remove your hard drive.
May 02, 2010 | HP Pavilion dv1000 Notebook
I have a Pavilion N5415 and when I turn it on all it says is ADMtek PXE BootROM can I fix it?
Sounds like it is trying to boot from the network and not the hard drive.
A few things to try:
1. Go into BIOS (usually F2 or Delete key at HP logo screen) and look for an option to change the startup. Once there make sure the hard drive is listed first and see if that works
2. Other issue is that your hard drive is not being detected by the laptop. If this is the case, you will have to remove and put back in the laptop, and hopefully it's just a loose connection--if it still doesn't show in the BIOS, your hard drive has probably bit the dust.
Hope this helps
Jul 11, 2009 | HP Pavilion N5415 Notebook
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
How do I remove the hdd from compaq nx9010?
Hi - follow these steps and picture:
. Remove the hard drive by following these steps:
a. Remove the two rubber screw covers 1 that conceal the
hard drive retention screws.
✎Spare part number 371808-001 should be used to replace
the hard drive rubber screw covers.
b. Remove the two PM2.0×6.0 screws 2 that secure the
hard drive to the notebook.
c. Use the notch in the hard drive bezel to slide the hard
drive forward 3.
d. Remove the hard drive.
864136d.gif If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 21, 2008 | HP Compaq Business Notebook NX9010
Removing hardrive from HP laptop
There are a set of screws on the bottom.  You unscew them (4 I think) and if should come right out
Oct 27, 2007 | HP Pavilion N5415 Notebook
HP Pavilion N5415 Notebook Logo
145 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
