Question about E-Machines eMachines Desktop PC
VGA doesn't work on my EMachines W2040
I have no VGA on my EMachines W204o. I can not get it to work. I tried Video cards and nothing will work Operating System: Genuine Microsoft® Windows® XP Home Edition CPU: AMD Athlon? XP Processor 2000+ (1.667GHz) with QuantiSpeed? architecture Monitor Bundle: eMachines® 15" eView? 15w2 Monitor (13.8" Viewable, 0.28mm dot pitch) Chipset: VIA KM 266 Memory: 128MB DDR (PC2100) Hard Drive: 40GB HDD Optical Drive: 48x Max. CD-RW Drive; 3.5" 1.44MB FDD Video: S3 ProSavage8? integrated (1 AGP slot available for upgrade) Sound: AC '97 Audio Network: 10/100Mbps built-in Ethernet Modem: 56K ITU v.92-ready Fax/Modem Peripherals: Multimedia Keyboard, 2-Button Wheel Mouse, Amplified Stereo Speakers Ports/Other: 6 USB 2.0 ports (2 on front), 1 Serial, 1 Parallel, 2 PS/2, Audio In & Out, Mic-In & Head Phone jack on front, 3 PCI slots (2 available) Dimensions: 7.25"W x 14.125"H x 16"D
  • bolderdash53 Jan 09, 2009
    my hp slimline works with the s video not the vga
    whats up
THIS TYPE OF PROBLEM IS CREATED SOME TIME DUE TO BIOS CONFIGURATION. GO TO YOUR BIOS CONFIGURATION ENABLE PLAY & PLUG DEVICES. ENABLE YOUR VGA TO INCREASE 64 BYTE. OR REMOVE BIOS BATTERY CLEAN IT AND INSERT LIKE SAME. OR SET YOUR JUMPER IT GENERALLY LOCATED NEAR YOUR CMOS BATTERY. AFTER THAT IF IT IS NOT WORKING U TRY TO SOME OTHER MONITOR. OR REMOVE ONCE YOUR VGA GRAPHIC AND TRY AGAIN. OTHER WISE GO TO YOUR SERVICE CENTER GOOD LUCK PURUSHOTAM
Posted on Sep 27, 2007
    Problem Solver:
  • 12 Answers
Test your system with another monitor. The problem could be your monitor. Hope this helps......
Posted on Sep 26, 2007
    Problem Solver:
  • 7 Answers
Take new vga graphic card which can be use in agp slot and upgrade ur system with it. ok bye bye
Ppowers upbutnovideo or beeps?
Space bar faulty as well?
Open the case and remove the video card and reseat it. If that doesn't work, you need a new video card.
The motherboard doesn't beep for standalone video cards. If the motherboard has onboard video you can try and getting into the bios by tapping F2, F10, or Delete at boot up. If the onboard VGA video works, you can select onboard video until you can replace the video card.
Nov 18, 2015 | eMachines T3092 Motherboard Battery
Asus p7h55-m black screen when i installed video card.. then i thought my video card is not functioning.. i get it and use on board vga.. its the same problem.. black screen, keyboard no light.. no si
Have you tried removing the new video card? Try that first.
The fact that your keyboard doesn't light most likely means that either your power supply is being pulled down by the video card or is now gone. Was your power supply rated high enough wattage for your computer with the new video card? If the video card was higher-end then it's possible that it killed the supply.
It could also be the motherboard that's gone. Static discharge when putting the video card in, or a bad video card can destroy a motherboard.
May 31, 2012 | ASUS P7H55-M LX Motherboard
I need a W2040 motherboard wiring diagram
must be easier to move the hd to a hd-caseing and start transfer to a another computer......to much time-consuming.
Mar 27, 2012 | eMachines W Computers & Internet
I replaced my ram and now my monitor won't work. I took out the new ram, put the old back in and still no monitor. Everything I read mentions video card...where is that?
Being eMachines it is probably on board VGA. You can check by looking to see if the VGA lead to the monitor plugs into a VGA card or the motherboard.
Unfortunately it may be caused by static discharge when the RAM was replaced if you didn't observe anti static precautions.
Hope its a VGA board fault but if you install a VGA card and turn off the on board VGA that will work.
Hope that helps.
Dec 30, 2010 | eMachines W4685 PC Desktop
Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
Vga driver need
http://www.emachines.com/support/product_support.html That should be where you can get the Video Card drive for your eMachines desktop.
Jan 11, 2009 | E-Machines eMachines Desktop PC
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
May 10, 2008 | E-Machines eMachines Desktop PC
GA-K8VM800M and GV-N76G256D-RH compatibility
Perhaps your power supply is not powerful enough for the new card.
Mar 01, 2008 | Gigabyte GA-K8VM800M Motherboard
VGA/MOTHERBOARD
yep. try disable on board card (if there is a setting) and use external video card.
Jan 08, 2008 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
862 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
