Question about Tivoli Kloss Model One AM/FM Radio
Tuning noise tivoli pal - Tivoli Kloss Model One AM/FM Radio
Transformer to old PAL Tivoli been eaten by rats. Where to find another for this old model
Try radio shack in States, Maplin in the UKand other similar retailers elsewhere. Also, if you can identify it try ebay, they carry a lot of these parts
May 30, 2015 | Tivoli (PAL) AM/FM Radio
Tip
Tivoli PAL volume problems
I posted this tip elsewhere but the FixYa site is, shall we say, challenging.<br /> After years of use my Tivoli PAL started having volume problems. The audio began popping, volume changed erratically, static, booming, almost feedback sounds.<br /> In my case, and others as well, I've gleaned, the problem was the volume potentiometer. Apparently it oxidizes over time and the poor electrical contact is the reason for the erractic audio.<br /> I'm not an electrical repair kind of guy, so this isn't pretty.<br /> The volume and frequency controllers are secured to the knobs with metal collars. I pried the collars loose and got the horizontal board off, I sprayed Stabilant 22 into the volume pot. There are other electrical contact cleaners as well.<br /> Put it all back together. Let the flud dry. Good as new.<br /> Good luck.
on Apr 27, 2011 | Tivoli PAL Radio
Tivoli radio
An internal fuse may have opened or there could have been spontaneous power supply failure.
Dec 08, 2017 | Audio Players & Recorders
Pal speaker
you should read the catalogue.
Mar 18, 2013 | Tivoli (PAL) AM/FM Radio
Tivoly pal spare parts
i think it need parallel circuit.
Mar 17, 2013 | Tivoli Audio Players & Recorders
Scratchy noise while tuning
I've found the best way to fix this is to drop alcohol on the tuner while turning it fast back and forth, with the power OFF.
Jan 19, 2010 | Tivoli Kloss Model One AM/FM Radio
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli iPal
send it back! I have had 2 fail this way.
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Tivoli Kloss Model One AM/FM Radio Logo
24 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Willem.
Willem.
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
