Question about Progressive Dynamics Inteli-Power PD9145A Series RV Power Converter
Low power output fuses ok - Progressive Dynamics Inteli-Power PD9145A Series RV Power Converter
Cigar lighter NO output with lights on.
what is plugged in there, we dont know?>
cell phone charger>? or the test tool or voltmeter, what?
no matter the CIG fuse is blown. replace the fuse, and will be good.
Feb 06, 2014 | 2007 Toyota Auris 2.0
My GE SCB1001KSS Convection Microwave does not work.
If it has a turntable does that work or not?
Oct 15, 2012 | GE Microwave Ovens
Active Speaker won't power up
If the speaker is OK, check the audio output components like ICs and transistors.
Jun 05, 2012 | Mackie SRM-450 System
Input fuse blows on switch on
In most power supplies, if the input fuse blows that fast it's because of some shorted component right at the AC input. Check for shorted rectifier diodes and filter capacitors. Both are common failures, especially if the equipment has been subjected to power line surges. If the power supply checks out OK, shorted output devices in the amplifier section is the next most likely cause. Check for low resistance on the outputs of the power supply. It's helpful to have a schematic diagram of the receiver for troubleshooting, and you can often service manuals or other information free or at reasonable prices on the Internet.
Jun 25, 2011 | Cambridge Audio Audio Players & Recorders
No or little ac output
By ac you mean receptacles, not ac welding?
If so what about welding output on AC (DC)?
If welding is OK then you may have breaker or fuse problem.
If welding output is also low or no output your problem is the generator.
You should check your gen rpm to be normal. If so you may have field problem: rectifier, AVR etc.
If you can measure the field DC voltage at rated rpm, if it is missing (very low) try to find any circuit broken.
If you do not succeed answer this instruction in order to give you more.
Jul 20, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
I just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Oct 17, 2009 | Infinity 475A Car Audio Amplifier
AMP POWERS UP, I CAN HEAR IT WORKING BUT THE SOUND IS REALLY REALLY LOW...
Hello korre,
Low output could be the head unit, the speakers of the amp itself. Start by isolating the problem.
1) Test the sub(s) on a known good output.
2) Input a known good signal. A portable with RCA preamp outs will work OK.
After you have eliminated the other components, troubleshoot the amp itself:
1) Check the onboard fuses. The M605 has 2 each 30A fuses just to the left of the power and ground terminals.
2) If it was just installed, then my first suspicion would be a problem in wiring. If one tiny little strand of your speaker wires comes into contact with another wire or ground point, it could present just enough of a signal path to ground out most of your power, and perhaps still allow the amp to seemingly operate normally (at least for awhile). Check power and ground too.
3) Make sure your head unit RCA's are plugged into the inputs and not the outputs.
4) Check the low-pass and subsonic filter settings. If low pass is turned all the way down, the amplifier would ONLY send frequencies below 30Hz to the speakers. Subsonic turned on and the low pass all the way down would effectively result in no sound.
5) Remove the top cover to access the mode controls and display. Check the input level.
If everything checks out, the amp probably has a defective component and needs factory/service center repair.
Hope this helps.
May 06, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I have a cambridge audio A300 V2.0 amplifier that wont power up. i've checked for power at the switch and there is power and i've checked on the main board at the fuses but there is no power there, the...
Hi there get a multimeter place across mains input on transformer,FIRSTLY DISCONNECT AMP FROM MAINS,set your meter to contiuity ,if good you should get a low ohms reading (resistance),then check the secondaries (output of transformer) either 3 wires or four going into amp board..if readings acroos all wires are low ohms then transformer is good if one is open ,transformer has had it ...hope this helps
Dec 08, 2008 | Audio Players & Recorders
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
Progressive Dynamics Inteli-Power PD9145A Series RV Power Converter Logo
27 people viewed this question
Top Progressive Dynamics Electronics - Others Experts
Are you a Progressive Dynamics Electronics - Other Expert? Answer questions, earn points and help others
