Question about Microsoft Windows XP Home Edition
Windows XP OEM OS
I had an E Machine burn out the MOBO and have built a new and better system with no OS. Ihave installed the old Hard Drive with Windows XP OEM (E Machine) in the new system and am having problems loading Windows XP. Do I have to purchase another full install of Windows XP?
  • Mick Richardson Sep 26, 2007
    I have been looking into this and am downloading the Live CD right now. I do have concern I have never heard about Linux free OS until the last 3 days and am finding problems with SATA RAID compatability an I am a trying to network the new system to 3 Windows XP laptops for file and media sharing is this going to be an issue with Ubuntu
  • 76 Answers
Yes, you have to purchase a new copy of Windows XP... Or alternatively you can try a freeware operating system such as UBUNTU. It does basically the same stuff your Windows did, just with a little more flair! http://www.ubuntu.com/
Posted on Sep 26, 2007
SOURCE:
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
How to reformat pentium 4 2.8g to windows xp
Since Windows XP isn't a filesystem, that doesn't quite make sense, but it sounds like you want to find or buy a Windows XP DVD, put it in the machine's DVD drive, enter the BIOS to check your settings and set it to boot from CD-ROM (it works for DVDs too, after all,) save settings and reboot...then install WinXP.
Keep in mind that if you have unsaved data on the system's hard drive, you would want to swap it out for a new one until Windows XP (or Ubuntu, or Fedora 15, much more modern OS which are quite capable of running WinXP programs using a program environment called 'wine' (no relation to drvino.com)) is installed; that way you're not going to overwrite old stuff you wanted to keep.
Then you can install the old drive on whatever interface is handy and migrate your settings over, make backups, use the old drive for pagefile or to try new filesystems and virtualization environments, etc.
May 23, 2011 | Microsoft Windows XP Professional
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
Apr 23, 2017 | HP NX9010: Pentium 4-2.4 GHZ, 512MB...
How to format the Hard drive without a recovery Disk?
What you are saying is like "how to listen to Bryan Adams' music on your PC without having a PC". You are gonna need atleast a OEM edition of the operating system if you want to re-install. The OEM version costs about 40 bucks on stores like ebay and Amazon.
Jun 13, 2010 | Sony VAIO PCG-K23 Notebook
Hello'I' gt a compaq d330 ut desktop Pc to arrange
If you format the hard drive NTFS format you should be able to install Windows XP. If the computer is old, the hardware may not work with Windows XP. Any computer built in last 8-9 years should work with Windows XP.
Nov 08, 2009 | HP Compaq Business Desktop d330
To insatall xp os in toshiba laptop fresh
make sure you use all the OEM disks with the drivers. if this laptop was not originally XP, use the previous OS that came with the system. and then upgrade to XP
Aug 16, 2008 | Computers & Internet
SDRAM REPLACEMENT
No not compatible! Your system is obsolete, almost impossible to upgrade anything. Socket 478, P4 cpu stuff, is the oldest system with any chance of upgrading or maintenance.Get a 'barebones' new system for $250/300 from the Inet [ ebay or simillar ]/ You will then get some value from the cost of the windows Xp if it is the full version or alternatively you have both original OS disc and windows Xp ugrade disc. If what you buy has an IDE hard drive. you can also install your current hard drive too, keeping what you have on it, as a slave drive after you have put your OS on your new machine plus any cd or dvd on your old machine.All this is simple and within widows framework and tools, no tech skill needed, just a screwdriver and a manual with your new barebones motherboard. Plug the old ide drive into the right socket from the conncecting braid, set the jumpers as per hard drive diagram on the back plate on both drives. One master, one slave.Remember NOT to format your old drive/ LOL/
Jun 25, 2008 | VIA Computers & Internet
New hard drive(s) in Dell4500s
You would have to contact dell for the OS disk.
I dont think you can install the hard disk in place of floppy drive. An external Hard disk would be a better option.
May 04, 2008 | Dell Dimension 4500S PC Desktop
Microsoft Windows XP Home Edition Logo
139 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
