My ricoh aficio mp c5000 prints with streaks/smudges. It appears that a roller is lifting part of the ink and then dropping it on later pages of the print. How can I ajdust/clean this?
Soulvisitor
  • 1113 Answers
SOURCE: black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Posted on Jan 11, 2008
  • 82 Answers
SOURCE: black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Posted on Apr 06, 2008
  • 49 Answers
SOURCE: black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Posted on Oct 08, 2008
Touch2Heaven
  • 145 Answers
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Posted on Oct 15, 2008
  • 42 Answers
SOURCE: Ricoh Aficio CL3500N is now
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Posted on Feb 16, 2009
How to clear memory in a mp c5000 macine
There are many counters in this machine. Jam, Error, Feed, All, Memory, Service Codes etc, that are located in the service software of the machine. If you don't know what each one does you can end up doing more harm than good by wiping out the wrong ones. Best to call a trained tech.
Aug 14, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Ricoh MP C5000 can't scan to gmail
once again the tech boyz mix up the formula ssl is a device unique identifier technology which has many permutations i'd expect it will take an act of God to get gmail apps to do this for a single device, and Ricoh is not in that business
keep an eye on the gmail apps forums and you might get lucky
May 29, 2012 | Ricoh Aficio MP-C5000
There are streaks on the side of the printed page
Are the Streak lines vertical or horizontal ? Most likely it could be due to Toner issue, Try to remove the toner and clean it and re-install it
Regards,
Suhail
May 15, 2012 | Ricoh Aficio SP C820DN Laser Printer
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
I am looking for a walk up driver for a ricoh Aficio MP c5000
please go to your aficio MP c5000's website and download it then install it.
Aug 10, 2009 | Computers & Internet
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Black smudgy streak in middle of printed page
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
99 people viewed this question
jasbo
jasbo
