Question about Kohler K-6340-BP-CP ProAvatar Kitchen Sink Faucet With Pullout Spray And Bl
Faucet leaking around body - Kohler K-6340-BP-CP ProAvatar Kitchen Sink Faucet With Pullout Spray And Bl
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
I have a leaking Delta single handle kitchen faucet, The leak is between the faucet and the knob at the top. I have replaced the ball, 2 springs, two seals, the cap with a notch in it washer for that and...
I may be able to help you. Some faucets are made with the option to have a base or to mount directly to the counter.The bigger washer might be the one that seals the faucet to the counter The leak out of the top of the faucet is probably caused from the plastic nut with the grooves in the top of it not being tight enough. The repair kit should have came with a tool that has a allen wrench on one end and two prongs on the other.Use the pronged end to tighten the plastic nut ,If the other parts where put in correctly this should cure your problem. If the faucet continues to leak you can get a pamplet that will give you instructions from a rep at the plumbing supply or on line in one of the sights for Delta Faucets.
Dec 13, 2009 | Delta 2402 Classic Single Handle Kitchen...
533-50 kitchen faucet leaks above base mount at pivot body when water is on and the faucet is pivoting to fill other sink.It dribbles out on counter top.Seems not to leak if faucet stays stationary.The...
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Sep 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
I have a price Pfister Marielle kitchen faucet. The valve body leaks when handle is in off position.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Aug 28, 2009 | Price Pfister Marielle Kitchen Faucet with...
How do you change the cartrige for easy touch american standart k
unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Jan 06, 2009 | American Standard Kitchen Faucet 6310 020...
How to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Oct 11, 2008 | Plumbing
Kohler K-6340-BP-CP ProAvatar Kitchen Sink Faucet With Pullout Spray And Bl Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
