Question about GPS
Navman f 360
Can not connect to PC via USB. It blocks the boot image (start)
4 Suggested Answers
SOURCE: pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
Posted on Mar 31, 2008
  • 6 Answers
SOURCE: Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
Posted on Jul 09, 2008
reyjoshua07
  • 1157 Answers
SOURCE: Hi I have a MY55T
Hi siboias,
Just another thought about your concern, have you tried resetting the unit and restore it from factory defaults? You can restore the unit back to the factory defaults by going to the "settings" screen and press on the "restore factory defaults". You may also try the following steps for additional troubleshooting.
1. Take the SD CARD out, reset and turn on the Navman.
2. When the Navman loads, push in the SD CARD.
3. Now go to the "setting" screen and press on the "restore factory defaults".
Hope it helps.
Thank you for using FixYa.
Posted on Apr 10, 2011
I need to download New Zealand maps (North Island) to my Navman MY80T
install the nav desk software to you p.c and connect the navman to the pc via the usb cable.
You will be prompted that a map upgrade is available through the NavDesk software. Once the unit has synchronized with the NavDesk software you will be informed that a later map is available. Once you select the map data, it will begin to download to your computer.
from
http://www.navmansupport.com.au/Navman%20FAQs/Map%20Installation/MY%20Series/MY80T/Map%20Installation%20Instructions/MYBase041___400.htm
May 13, 2017 | Navman GPS
I can't boot from the Internal, or via an External USB connected \r\noptical drive? Any suggestions? Is a boot via a Flash drive possible on the PCG-K45? Many thanks for any input...
hello, have you tried changing device boot orderfrom BIOS?
you should change device boot order or press the appropriate button (commonly F10) during POST (when laptop starts to initialy work, it writes which button the first 5seconds that it starts to work) and then you will see a box that shows all the availiable devices to try to boot from. All computers and laptops can boot from any internal or usb if these devices work properly and have a proper image to boot from.
Sep 18, 2011 | Sony VAIO K45 Notebook
Cant connect to my navman m 400 to my computer
Open your MioDesktop, attach the navman to computer via usb cable provided with it when you purchased...make sure your firewall allows you to connect to mio server.
Nov 24, 2010 | Navman Mio M400 Car GPS Receiver
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
Nov 22, 2008 | Navman GPS
Navman f-20
Change bad internal MMC Card for a new one, connect via USB to PC , run f20servicepack1.exe. Don't forget to install Navman's USB drivers ( c:\program files\navman\f20 service pack\USB\ .
May 28, 2008 | Navman F20 GPS Receiver
Pin 570 wont boot after hard reset
Mar 30, 2008 | Navman PiN 570 GPS Receiver
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
pamelathanson@aol.com
Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
