Once it fills it will not finnish the cycle - Washing Machines
    Problem Solver:
  • 8 Answers
You didn't mention what kind of machine you had. On my Whirlpool Duet, once the pump filter got plugged. Then later the the pump itself needed to be replaced. Actually, replaced the pump twice through the years.
Then several other times it was the level sensor. More specifically, the tube to the sensor got plugged. It happened so often, I don't even replace the screws on the top panel anymore. I just pop of the top panel, reach in and disconnect the tube from the sensor, then blow through it to clear. Restart cycle.
Ultimately, I had other erroneous error codes, then replaced the sensor (~$50) and most of those problems went away.
Posted on Oct 16, 2013
3 Suggested Answers
  • 156 Answers
SOURCE: will not finnish cycles
ck the lid switch
Posted on Mar 03, 2008
  • 713 Answers
SOURCE: Smartdrive 508 fills very slowly, seems to
Hi just read your posting.Is your complete model number GW 508? The fault with your machine is either your inlet hose filters or your water valve filters are blocked or one or both of your water valves are faulty.Turn off the water to your machine and remove the inlet hoses one by one.Check the amount of water coming out of the taps and check and clean the filters,if your inlet hoses have them, at each end of both hoses.Also where the inlet hoses connected to your machine check the filers on the water valves.If all the filters are clean and you still have the problem then the problem will be one or both of the water valves.Please reply on how you got on or for additional assistance.Hope this helps and looking forward to your reply.
Posted on Aug 01, 2010
My machine does not finish a cycle it is on all day, what is the problem
Some machines dont finnish the fast ( spin cycle) because the motorcarbon brushes ar worn, usually a inexpensive repair, say £ 15 for parts 1 or 2 hrs labour.
pete
Nov 11, 2010 | Indesit W 123 Front Load Washer
Water will not fill during rinse cycle water just keeps runningg?
That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Not usin tablet, finnishin cycle and heatin water
This is an electrial issue.
If you are uncomfortable working with electricity get a pro.
If the power to the heater does have some sort of temp control. That may be the issue. It heats till the Thermo switch opens. Sometimes they fail.
Mar 24, 2010 | Dishwashers
Code F02 in middle of cycle, wont finnish cycle,
unit is taking to long to drain brad,,check your drain hose not blocked of kinked,,,clean your pump filter,,check your pump,,onthejob
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Not finnishing cycle AWM 8121 washing machine
Can you manually advance it through all the steps of the cycle? If so, you can live with it until you replace the little timer motor. (I once carved a tiny wooden gear to replace a tiny nylon gear on the timer, and that worked fine for another 20 years.) If not, then I'd say the control unit needs replacing.
Nov 10, 2008 | Whirlpool Washing Machines
Bleeping dishwasher
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
  • Nov 03, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    Washing Machines Logo
    Top Washing Machines Experts
