Question about LG VX8300 Cellular Phone
Phone says "car kit"
It went away when I plugged the charger in, now I can hear the person on the other end, but they can't hear me. The phone did get wet, as my 11 month old was "sucking" on though it was a teether!
Re: phone says "car kit"
I brought my phone into verizon and they cleaned the charging terminal and it has worked fine ever since. My phone was accidentally dropped into water. if they tell you it can not be fixed use a small brush to gently clean the terminals on the bottom of your phone.
Posted on Sep 28, 2007
0 characters
3 Points
Phone got wet now its stuck on car kit
Look at the bottom where the charger typically goes, does it look GREEN?. If it's take a DRY tooth brush and brush out all the green stuff. Restart phone and see if it went away. Good luck.
Nov 07, 2008 | Cell Phones
Getting an error that says car kit on phone
Mine said car kit and I kept reading it was because it got wet, and my phone didn't get wet. I noticed a little corrosion where I plug the phone in starting to form and I rubbed a little off and the car kit on the main screen went away.
Sep 08, 2008 | LG Cell Phones
Car kit setting removal
"car kit" usually means the phone got wet...
unfortunately there is no way to fix it...
Jan 31, 2008 | LG VX9800 Cellular Phone
Vx8300 stuck in car kit
I just ran into this problem myself (besides that fucked up white main screen i have). So after reading all these other solutions i played with the thing and found that its one of the right-most pins in the charging port. Probabily a pin touching the metal housing or another pin completes the same electrical circuit used to determine if a car kit is hooked in. I figured this one by shoving a knife through the opening to clear out any debris and every-swipe made the "car kit" banner dissappear. so check for pins touching something it shouldn't. ( i said F-it and ripped that pin out!)
Hope this helps more
Jan 05, 2008 | LG VX8300 Cellular Phone
Set to car kit.
I reinserted the wall charger a couple of times and it made the "car kit" go away. My guess is that two pins in the little connector inside the phone somehow got shorted together (dust or something). I saved the butter knife soloution for my last ditch attempt as I wasn't sure that shorting all the pins wouldn't increase the chances of damage to the phone. The post above definitely go the creative juices flowing since we had no idea how it got in "car kit" mode.
Dec 11, 2007 | LG VX5200 Cellular Phone
Car kit
same problem....i found a neat solution to this one..see if it works for you too...i simply charged my phone as much as possible, drove to a nearby lake(you should do this while its light outside for best effect's to be noticed), and then i THROUGH the damn thing as farrrrr as sure that you spend the time so as to take it all in..then, go to your nearest retailer and get any new phone that does not say LG on the worked for me and i'm glad to say that it definetly decreased any homicidile thoughts i had been having due to the issue.
Nov 02, 2007 | LG VX8300 Cellular Phone
Car kit on display screen
It's actually something wrong with your phone. The connector on the bottom of the phone may have gotten wet. If you are comfortable taking the phone apart you can clean the connector w/ 99.5% isopropyl alcohol and a soft bristled brush. Good luck.
Sep 05, 2007 | Cell Phones
Says Car Kit on phone but has never had a car kit hooked up to it
A clarification on solution #1: Try pressing the tip of the knife (I used the end of a nail file) onto the lower right hand side of the charger area. That's what got it for me. If that doesn't work, try other parts of the end...
Aug 16, 2007 | LG VX5300 Cellular Phone
Cell Phone LG VX3450
Well from my experiences, and I manage a wireless store, you have gotten the phone wet in someway. It could have been anything from just sitting in the sun or being in the bathroom when you take a shower. You may try putting the phone in a bag of white rice for 8 hours or so and that could make it come out of car kit.
Jun 18, 2007 | LG VX3450 Cellular Phone
"Car Kit"
this model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Aug 06, 2006 | LG VX6000
LG VX8300 Cellular Phone Logo
138 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
