Question about Hitachi Air Tools & Compressors
Hitachi portable washing machines dose not spin
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
mumma_1
  • 903 Answers
SOURCE: wash cylce
the programmer may be faulty.
Posted on Oct 23, 2008
SOURCE: front loading washing machine will not tumble or spin
This sounds like a drive belt porblem. The belt that connects the drum motor to the drum has slipped/broken/worn out. A new drive belt will most likey fix this one...
Alternately, a loose or broken pulley. I don't suspect a bad motor, since you say you can hear it clicking and whiring...
Posted on Jun 10, 2009
MARCLAVORIS
  • 110 Answers
SOURCE: washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Posted on Mar 07, 2010
  • 6277 Answers
SOURCE: not spinning dose it have
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my comprehensive guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 29, 2011
I got C4 error on Hitachi FX80GJ washing machine and it stopped spinning. How can I fix it ?
Hitachi washing machine top loading is Sher coming C4 is dry too much sound coming
May 16, 2015 | Washing Machines
Washer washes but dose not spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore 98702 Stacked Washer/Dryer
Hitachi washing machine sf6500px washes ok but wont spin, digital signal says dE, does anyone know what that means please?
im not 100% on hitachi gear dont see alot where im from, but for most washing machines DE normally means the lid is open as they have small magnets in both the lid and frame of the washer, most machines will not begin to spin if the lid is not shut they will fill and wash but not spin purely as a safety precaution, if the lid is shut it means the lid (you may have a latch that actually locks the lid shut or just a reed switch magnet sensor that simply detects if its opened) reed switch or lid lock is broken or faulty normally pretty quick and easy to repair
Jan 18, 2011 | Sprint Hitachi P300 Cellular Phone
It dose not perform the drying process and the water does not drain out.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Problems with a washing machine not spinning or not draining are often inter related..</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />If you are having a problem with your top load washer then check out this tip...<br /><br />Washing Machine does not Pump or Spin<br /><a href="http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin" target="_blank">http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin</a><br /><br />If you are having problems with your front load washing machine then checkout this tip...<br /><br />Front Load Washing machine not draining and or not spinning<br /><a href="http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining" target="_blank">http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 27, 2010 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
This washer wont spin but it dose drian
Most likely your motor coupling is busted.
part number is 285753A
May 17, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Aug 31, 2007 | Washing Machines
Air Tools & Compressors Logo
13 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
