Question about Fellowes Jupiter 125 Laminator 5215801
Fellowes jupiter 125 laminator janned, can't open top to get to the gears
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Fellowes Jupiter 125 Laminator will not turn on. I've plugged it in, flipped the switch in the back, pressed the standby button to turn it on, just beeps at me. No other lights come on.
other than to ask did you take it out of standby and wait the 4-8 minutes for it too warm up ? I do have this phone number 4 u to call for help with this ,its out of back of my book ----b9gs27mjwtojdrmwfiqzolwb7uddvtk0jdb1qmk8qbuwdvylpkv71k2poierczcxrtrww73wvjcc7bk7jwoa6nmprqepzu9eoraynmuf+jerezcll0dvq0v1hqta91udnuvttmpvxzuspacoqsztxzvu4zeivsawqa+deugdqgcia0bgianayigdqgcia0bgianayigdqgcia0bgianayigdqgcia0bgiaple339yfgz6xceiraaaaaelftksuqmcc
Aug 18, 2016 | Video Game Consoles & Games
Need a gear box for a Fellowes Voyager 125 laminator
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Apr 29, 2015 | Fellowes Voyager 125 Laminator
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
Beeping and not turning on
This is the second laminator of the same model that is beeping and not turning on. What do we need to do to get this machine operational?
Dec 18, 2013 | Fellowes Jupiter 125 Laminator 5215801
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i...
once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
Mar 22, 2012 | Fellowes Saturn SL 125 12.5-Inch Laminator
A laminating sheet is stuck inside machine. You can't see it from either end and machine smokes when turned on now. It is a Fellowes EXL 125-2.
OOOOooooooooohhh!!!!!
Hate to tell you, BUT, the laminate is melted on the fuser. You learned the hard way, htere are specific laminates for different types of machines, the reason is because of the amount of heat it can tolerate. If you look in the back of the box it will tell you what machines they are good for, if yours is not listed, you should look at the manual or the website.
You will have to take it apart and remove the melted plastic, with hopefully minimal damage to your machine, otherwise the fuser will need to be replaced.
Sep 05, 2008 | Office Equipment & Supplies
Fellowes Jupiter 125 Laminator 5215801 Logo
123 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
