Question about Citizen CX80 Scientific Calculator
My sharp el-531x shows alot of zeros - Citizen CX80 Scientific Calculator
Help! My Sharp EL-531x calculator is not calculating correctly.
First subtract the 106 from the 240, then divide by 800. You need a parenthesis around the first two numbers, then it will work.
Apr 06, 2017 | Sharp el-531x scientific calculator
HOw to change FSE code on Sharp Advanced D.A.L. EL-531X
To change the FSE code on your SHARP calculator press SETUP and choose 0. FIX means that it shows you all the decimal places. SCI is scientific notation, ENG changes the scientific notation in groups of 3's. NORM1 and NORM2 are your normal number ranges, however norm2 starts from zero and anything negative will be written in scientific notation.
Jun 02, 2014 | Sharp Office Equipment & Supplies
Turn off the fix mode
Press SETUP and choose 0 for FSE. Then choose 3 for Norm 1. This will put the calculator back to the original setting.
Mar 20, 2014 | Sharp el-531x scientific calculator
All my answers come in decimals on my sharp el-531x and i want to turn it to normal
Press the SETUP key, press 0 for FSE, press the down arrow key, and choose 3 for norm 1. The calculator should return to normal. If all else fails, there is a reset button on the back.
Dec 08, 2013 | Sharp el-531x scientific calculator
Sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
Feb 27, 2013 | Sharp el-531x scientific calculator
EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Feb 21, 2013 | Sharp el-531x scientific calculator
Citizen CX80 Scientific Calculator Logo
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
jay kaye
jay kaye
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
