Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
Fridge has water in it which freezes into sheets.
Seems to be coming from upper freezer compartment. Lots or water. Water leaking from inside fridge seems to becoming from upper compartment.
  • 113 Answers
See if there is a drain line going up the back if there is you should be able to take if loose to see if its stopped up
Posted on Apr 24, 2009
Frost in top freezer - water leaking in refrigerator - ice maker not working
go through this link it will help you
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Oct 08, 2008 | Frigidaire FRT21HS6D Top Freezer...
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
I have a roper model RT14ZKXDWOO and the freezer is working fine but the refrig is warm. I took the panel off the back of the freezer and it is full of ice. What should i do next? and is there a diagram...
Hi,maybe I can shed a little light.I don`t know where the defrost timer is,but I would melt the ice with a hair dryer and real warm water(it will make a mess so be ready).There will be a drain inside of the freezer compartment,on the inside.Some how the rear panel inside the freezer compartment comes out.You may have to take apart the whole inside of the freezer compartment just to remove this rear panel.But when you do look for ice build up on bottom of freezing unit,and the rearof the freezer compartment.Melt this ice the same way earlier described.You will find a drain that starts inside the bottom-rear of the freezer compartment.This drain goes all the way down to the bottom of the fridge.You will find a very shallow drip pan under the fridge.This pan will most of the time only receive a little amount of water at a time and evaporates quickly.Now while you thaw this drain,water will start draining threw the drain,if it is not stoped up with food particles and such.This would be a good tome to blow threw this ine from the bottom where it drains into the pan underneth the fridge.Then blow threw it at the top in the freezer compartment.You can use a air tank with a blow gun.Be sure to pour water threw and down this drain to wash out all particles left behind.Clean the freezer compartment out good(the particles of food and such) and reassemble the freezing unit.plug fridge back up and set the freezer control to a respectfull setting(not the coldest and not real cold)and set the frideration to a decent setting for food preservation. Let the fridge and freezer run 12 to 24 hours to see if your problem comes back,and then time will tell if your defrost timer is bad,or is working like it should.When the drain clogs,it starts freezing away from the defrost elements and continues freezing the blocked water untill it overtakes the coils .The defrost and the timer don`t stay on long enough,or hot enough to overcome the ice.This is the reason you should try this solution first.If I can help you anymore,let me know roniecon@gmail.com /let me know how it turns out
Jul 12, 2009 | Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Refrigerators Logo
198 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
jeff5may32
John Tripp
John Tripp
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
