Hi i am having problems with my 37" LG lcd tv. Model 37lB1DB When i power it on , i hear the relays click on but i get no picture or sound; on this tv at the bottom the power light indicator and the cassette tape light both come on but does nothing else after that. Upon opening and testing i found the 12v outputs to be 11v but the rest are okay and on the mainboard there are 4 led's lit but one is out which is next to one of the power connectors, i wonder if its a problem with the power supply or the mainboard. P.S Its nothing to do with fuses, loose wires, bad soldering joints, buldging capacitors as these have been checked over. Or if anybody knows what the exact fault could be? I can send pictures and a video if it would help. Power supply is an LGLP2637HEP Mainboard is PD61A thanks regards jonno
  • 1 more comment
  • Jonathon summesfield Apr 24, 2009
    Thanks, but i brought it off ebay, and i might repair the SMPS.
    I have also noticed aswell the power LEd blinks 7 times then the VCR tape lights up.
  • Jonathon summesfield Apr 27, 2009
    Hi thanks mate, now i know this infomation i want to know if anybody would know how to fix this. Closer inspection is that the 12V Rail comes from a YG862006 SCHOTTKY Diode, would this cause the problem where the voltage of 12v would be lowered to 11v?
    Thanks , ive been wondering whether the main board was the problem in the first place, when i first brought it the bloke said a tv repair man said something about the mainboard, but this was off ebay and you dont really know what to expect with a power problem as you probably know yourself lol. Now i know the powersupply is fine i can go about and sorting out the mainboard and find the regulator I.C and check for voltage. And since there is an indication led out on the mainboard that also gave me an idea that there could be something wrong with the mainboard, once the relays click all but one come on so thanks very much :)
    i will go have a look at that and report back.
    Novelist:
  • 166 Answers
Hi Junno,
Firstly, I would like to ensure you that your power supply is not having any problem. As you were suspecting because of 11V, I must make you sure in electrnics systems its not very sure that always power is exactly what needed. In all electronics equipments we keep a range of DC power supply...
So please, don't worry about power supply. Now come to your problem. Actually, as we are sure that power is OK then in this mainboard problem is also possible but as you have already told that RELAYS are switching properly,it means only internal circuitry of mainboard can have problems.
Since relays works out of modules of Mainboard, so it also refers that mainboard is having some problem. Also, I wanna give you more assistance on such problems.
Generally it is found that these problems are due to regalator IC of mainboard. And solution of such problems needs CRO testing and module-wise checking. And its very affordable too. So, i recommend you to go for a technician & let its regulator IC (named as 7812) to be cross-checked again. And then that person will check your graphic adaptor too.
Surely you will get rid of this problem by this. If you are enough technical person, then do this yourself and no need to depend on any repairman.
Thanking you...rate this solution if it was really helpful to you.
With Regards,
Shyny
Posted on Apr 27, 2009
  • Shyny Saxena
    Shyny Saxena Apr 27, 2009
    No not at all. As i said above, 11v doesn't mean that your mainboard won't work. Yes, is true that Schottky doide ensures 12V but when we test main boards in our testing departments, we assume a range of voltage supply, ie. from 10.4 V to 13.5V.
    So please don't worry about power supply.
    With regards,
    Shyny
  • Shyny Saxena
    Thanks sir. Surely you will get rid of this problem. As you can see, its very logical too that power supply can't have problem. Anyways, i hope you really understood my suggestion.
    Hope for best & let u enjoy your T.V. soon...
    I'll wait for your response.
    With Regards,
    Shyny
  • 19,396 Answers
6 or 7 blinks on LG tv is not a fault code. It is only saying that the TV is on protection mode because there is a fault.
LG LCDs have no blink code.
I do not have service manual for your model, but you can check similar models below:
32lx4dc
42lp1d
You can get service manual for your model here, you won't find blinking codes, but you can followi troubleshooting diagram to test the tv : getMANUAL.com
Posted on Apr 24, 2009
  • Navicura Oct 28, 2010
    I have the same PSU (LGLP2637HEP) but a different LG LCD TV.
    My problem is that I get a HIGH (5V) at the 5V ST (Standby), but my ACD (AC Detect) is LOW (0V). Any ideas as to what could the problem be? I do not have, nor I can find the PSU Schematics.
    No bulged capacitors and measured the capacitance, and I have tested multiple parts already
  • 59 Answers
Hi
That sounds like a power supply problem. Possibly a voltage rail has gone down. It might only be a blown fuse or a blown component but it could be something more serious if you have already tested the fuses.
Unfortunately, the problem requires an engineer's visit or you could try and find a new power supply on ebay or somewhere else and replace it yourself.
I believe though that you are within your consumer rights to have the TV repaired by the retailer or manufacturer even if the guarantee has run out. Something to do with the TV not providing service for a reasonable amount of time before failing.
Hopefully someone will post information about your consumer rights because I know nothing about them!
All the best
Power, I can hear the relay keep clicking every 2 second. will not power up.Any idea as to what can cause that?
Sounds like main board fault. Contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 17, 2014 | Sharp LC37SB24U 37 in. LCD TV
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
No sound on lg 37lc7d 37 in lcd hdtv
Apparently something else has failed on the circuit board(s).
Nov 10, 2013 | LG 37LC7D 37 in. LCD HDTV
Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
My lg 37 inch lcd works fine for five minutes then a big popping sound happens , i loose picture and sound but power remains, after this it will either keep popping or picture and sound will return for...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 17, 2011 | LG 37LC7D 37 in. LCD HDTV
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
Difficulty hearing Samsung LCD tv even with volume up to 100%
Some models are just that way. I would invest in a small surround sound system for them.
Jun 18, 2009 | LG 37LG30 37 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
966 people viewed this question
Top Televison & Video Experts
Electro Med Services...
