Question about Luggage & Travel
How to change the in-line skate wheels on my Merrell duffle bag? or who does those repairs?
What are Zuca bags? And from where can I get these bags?
Zuca bag is a marvelous creation, it was designed by a mother who was concerned with her son's back problems due to heavy books he had to carry in school.
Zuca Bags especially excelled in figure skating as a prime choice for an ice skating bag for all ice skaters big or small. Zuca bag is a unique creation and allows its user to be creative from the start.
You can get the exclusive deals on the Zuca bags on figureskatingstore. It is the best where you can get the different variety of the Zuca bags.
Oct 14, 2016 | Zuca Sport Kit Black Frame ZuPet Carrier...
Is there a way that I can fit more clothes into a duffel bag?
There are a few things that you can do to fit more clothing into a duffel bag, you can use space or vaccum pack bags to get air out of the clothing. You can roll your clothes so that they are packed more tightly. If you are flying you want to keep inmind that while you can fit more in your bag doesn't mean you should because air lines charge a lot for over weight luggage.
Sep 17, 2013 | Luggage & Travel
The wheels on my roller skates are vibrating and sluggish when I skate, what could cause this?
. It seems as though your line bearings inside the wheel need to be changed. To do this you should: Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminium, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
Jan 17, 2013 | Sport & Outdoor - Others
How to change the line bearings in my skate wheels?
Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminum, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
How can I maintain my figure skating blades and boots?
Keeping your figure skating boots and figure skating blades dry is the key to their longevity. Figure skating blades should never be stored in plastic blade guards!! Always wipe off any moisture from figure skating boots and blades. You can use teri-cloth blade covers, Zookers, or Blade Blankies to store figure skating blades. It's typically a good idea to occasionally take your figure skates out of your skating bag to let them "air out". Also, never leave figures skates in your car during warm weather seasons. Most figure skates are heat moldable and leaving them in the car can misshape and ruin your figure skates.
Answer from: http://figureskates.discountskatewear.com/t-Faq-figure.aspx
How to change a wheel on a roller-skate?
To change a wheel on your roller skate please do the following:
Unscrew and remove the axle bolts from the front wheel with an Allen wrench. Pull the front wheel out of the wheel frame. Remove the bearings and spacer from the wheel. All components should slip out together. Place the spacer and bearings into the new wheel. Place the new wheel on the wheel frame. Replace the axle and tighten it using the Allen wrench. If your spacer is aluminum, tighten the axle as far as it will go. If your spacer is plastic, tighten the axle almost as far as it will go, then loosen it slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If the wheel wobbles, tighten the axle. Repeat the previous steps for the remaining wheels.
Jan 13, 2013 | Sport & Outdoor - Others
One of my bower roller skates has a wobbly when can I fix this or will I need to buy a set of wheels?
Does any one make a carry bag or soft case for transporting the ProLine PL-400. The stand measures around 54" x 16" x (7-8)". I would like to have a case that I can use when I go to a hotel...
I have never seen a carrying case for these offered anyplace... they can be a pain to handle. You MIGHT try to get someone to make a heavy duty cardboard box to carry it in. These are a heavy duty stand... making almost any hard case would triple the weight. They custom make cases for mixers but that type would weigh about 50 pounds for the case alone. If I were making one, I would do it something like the mic/speaker stand cases are with a zipper down the opening. Maybe use canvas... but DO use a heavy zipper... getting the "ears" in and out of a duffle bag would certainly be frustrating to the max.
Sep 06, 2011 | Pro Line Proline Pl 400 Double X Braced...
I can't seem to find these in a size 9 ANYWHERE!! Any suggestions?
Are you certain you want Brown? Zappos.com has them in a 9 in Black.
http://www.zappos.com/merrell-saratov
On-lineshoes.com also has it but once again only in black.
http://www.onlineshoes.com/womens-merrell-saratov-black-p_id156136
I kinda think they might not be available in Brown. Have you considered the Merell Eden Peak in brown?
http://www.onlineshoes.com/womens-merrell-eden-peak-multi-brown-p_id198352
or the Merrell Tetra?
http://www.onlineshoes.com/womens-merrell-tetra-launch-waterproof-cherry-brown-p_id89754
Nov 15, 2010 | Merrell Saratov 9 M in Brown for Women
Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Mar 04, 2009 | Toys
Luggage & Travel Logo
Top Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
