Question about HP TouchSmart Computers & Internet
I need to change cmos battery on HP touch smart 310 pc
2 Suggested Answers
  • 65 Answers
SOURCE: the intergarted webcam on touch
check that it has not been disabled
Posted on May 21, 2011
Wich cmos battery for the hp 600 touch smart
which, ?
so you found it and removed it? already, why not say that.
hp 600 what, what is the service tag full model number
NO PC stated, clear enough to answer. accurately
read your service tag, see that full model name.>?
the 600 desktop the coin cell unsnaps, and the 3vdc battery partnumber is clear as day on it, and sold in most stores
we have them even at Walmart here,it the Watch Department.
the 600 laptop is a whole other matter.
its is wrapped in plastic and has 2 leads, like photo below.
in shop we make them from scratch using a DT battery above.
this is not a p/n its a date code,2010
touch smart what???????????????
allinone PC? what? it has a full name and more important a real model number like photo 2, wrong example
see that Model # there, only that fact matters, !
Jul 07, 2017 | HP Computers & Internet
Hp xw4600 work satation "Smart card reader not present" at boot
Although it is from another model...
See HP Compaq dc5700 Business PC Computer Setup F10 Utility
Reset the settings of the BIOS but make sure you know the parameters you need.
Sep 22, 2016 | HP xw Computers & Internet
How to change the cmos battery on a touchsmart 310 1020
  • Study the Upgrade guide from HP before starting so you can remove the battery if you drop it in the machine by accident. As of the time of writing, there is no dedicated guide on how to change this battery the long way. Because of this I am going to recommend reading the HP upgrade manual for now. Once you have the back removed, remove the screws from the motherboard EMI shield. These are all the same length, and can be sorted in one pile. Find the battery and remove it from the system once you find it.
  • You should ideally use ESD safe tweezers for this procedure. You are after all, poking around at the system's internals semi blindly. It doesn't hurt to be sure.
  • Jul 19, 2016 | HP TouchSmart 310-1020 All-in-One Desktop...
    How do remove smart card Authentication errors in my hp compaq?
    Try this Press F10 and change the security settings to remove the need for the smart card to login. This will eliminate the authentication errors associated with the faulty card.
    See this web page on how to do it. HP Compaq dc5700 Business PC Computer Setup F10 Utility
    Feb 16, 2015 | HP Compaq d530 SFF PC Desktop
    I cannot find the webcam icon for my hp touch smart 310 pc
    In many laptops You can't see the Webcam Icon, so try to install the third party webcam application.
    Hope you understand
    Oct 18, 2013 | HP TouchSmart Computers & Internet
    Hp envy of unlock passeord
    Which operating system ???
    CMOS (Complementary metal oxide semiconductor) refers to the battery-powered, semi-conductor chip located on an HP computer's motherboard.
    It is where the BIOS stores important information regarding the PC's system configuration. CMOS is required for an HP laptop and its hardware to run stably.
    Sometimes, however, it is necessary to clear CMOS, such as if you lose your BIOS password or your BIOS is corrupted.
    Clearing CMOS on HP laptops varies depending upon the model, but for a lot of laptops, the process simply requires removing the battery for a short period of time.
    Power down your HP laptop. Remove the AC adapter and any other peripheral devices. Turn over the computer so that the bottom side is facing up.
    Ground yourself, either by touching a piece of unpainted metal or by wearing an anti-static wrist-strap.
    Locate the battery. This will vary depending on your laptop's model, but it is usually located on the back, near the rear of the laptop.
    Review your laptop's documentation to find the battery, if needed.
    Many newer models require that you remove the battery by releasing or holding down one or two latches, then gently pulling the battery out.
    Some models may instead require that you unscrew the battery from its compartment.
    Leave the battery out of the compartment for at least 30 minutes.
    Do not attempt to turn on the computer and do not touch the battery within that time.
    Some HP laptops may require you leave out the battery longer to clear CMOS, others might take only 10 to 15 minutes to reset.
    Ground yourself, then put the battery back into the HP laptop.
    Snap the battery latch into place or screw the cover back on, if necessary.
    Removing a Bios - CMOS Password
    http://www.dewassoc.com/support/bios/bios_password.htm
    Disable Fingerprint on an HP Laptop
    Many HP laptops include a fingerprint scanner to enhance the security of your computer.
    When the fingerprint scanner is enabled, the computer requires a fingerprint scan to log onto Windows.
    Disable the fingerprint scanner if you do not need or want this feature.
    With the fingerprint scanner disabled, you can log on to Windows using a password.
    You can enable the fingerprint scanner anytime you need to.
    Access the Device Manager on your computer.
    Select "Control Panel" from your computer's Start menu.
    Click "Hardware and Sound" and then click "Device Manager."
    Find "Personal identification devices" in the "Device Manager" list.
    Click the "+" sign next to "Personal identification devices."
    This opens a list of all of your devices.
    Click on "Validity Sensor."
    Select the "Driver" tab at the top of the properties window and click "Disable" to disable your fingerprint scanner.
    The button changes to "Enable" and you can enable the fingerprint scanner at any time.
    Click "OK" to exit out of the window.
    Jun 27, 2013 | Computers & Internet
    Hi we have had a power spike and I have had to flatten and rebuild our Compaq EVO 310. This resulted in losing the drivers and then finding out that my partner does not have the original compaq disks for...
    hello: the drivers you need can be download on hp /compaq site and reset the bios you can take battery out and the bios are back in standaard settings with startup you can make your own settings again
    Nov 04, 2009 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
    DV2000 Bois password
    If you are talking about BIOS Password which is being asked when you try to access any feature of the BIOS, I am sorry, it is not possible to retrive or reset.
    However, if it is the Startup Password which is prompted to enter immideatly you start the Notebook, you can try removing and replacing the CMOS / RTC / BIOS Battery.
    1) Turn off the Notebook and remove the Battery and Power Adapter.
    2) Follow the instructions to remove the BIOS Battery provided in page number 125 of 310 in the manual :
    http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
    Start the Notebook with the CMOS battery removed with the power adapter and turn it off once you see the HP logo.
    Remove the Power adapter and insert back the CMOS Battery and fix the door that covers it.
    You should be able to use the Notebook normally.
    Jul 31, 2008 | HP Pavilion dv2000t Notebook
    Computers & Internet Logo
    102 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
