Question about Car Audio & Video
Anyone have a Visteon cd6 wiring diagram? - Car Audio & Video
Ford 6000cd wiring diagram
Viewed from the back: make sure you have all grounds connected (one is not a ground but must be grounded) Batt Ignition and Illum can be connected to 12V
wdwgfphyonwpwaaaabjru5erkjggg==
Jan 18, 2014 | Car Audio & Video
I have a 2005 Toyota sequoia that has an aftermarket visteon intalled in the headliner. Anyone know where the inline fuse might be installed as power to the unit is interrupted?
The easiest way is to check around the battery for after-market wiring. If there's no aftermarket stuff hooked up to the battery, someone may have forgotten to re-hook it back up, and it may have fallen to the side of the battery.
The other option is to actually follow the wire, starting from the Visteon and going back. Look toward the trim around the windshield. The installers were headed for the battery, so head to whichever side your battery is on. Remove the trim for a better look if necessary. OEM harnesses are usually encased in black plastic or tape, so the after market wires should stand out. Follow them to the engine compartment.
Be aware of correct polarity when hooking the wires up! The wire with the fuse in-line will be the positive (+) one.
Hope that helps.
Good luck! :)
Apr 19, 2013 | Cars & Trucks
Wiring diragram for visteon MB8008
email me @ ilouden@europe.com - I have it!
Aug 25, 2012 | Visteon Car Audio & Video
I want to reuse my Honda Odyssey video monitor
I have this same question. Did you get any answer?
Jul 19, 2009 | Nokia LD-1W GPS Receiver
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
