Roland cut studio
Hi, I have a problem with roland cut studio. It seems that the program is reading the height and width of the job the wrong way around. The height and withs of the material are set ok in the properties in the application but when i try to cut a job across the width of the roll of vinyl, it cuts the job down the length of the vinyl and vice versa. I haved checked through all settings and cant seem to rectify this. Can you help?
2 Suggested Answers
  • 3 Answers
SOURCE: Manual for Roland Cut Studio Software
Here is a link for the Cut Studio manual direct from the Roland DGA website.
http://support.rolanddga.com/docs/Documents/departments/Technical%20Services/Manuals%20and%20Guides/RU_CutStudio_Basic.pdf
You Tube Videos:
part 1 of 2
http://www.youtube.com/watch?v=5IPzc2YjRS4
part 2 0f 2
http://www.youtube.com/watch?v=iHLHFz80_Gg&feature=related
Posted on Feb 24, 2010
Hi we measured 12 meters long by half meter width how much is that in cubic meter
thats 6 meters square need another factor[HEIGHT ] for cube 12x .5x ?=CUBIC
Jul 17, 2016 | Garden
Screen Adjust
You can't. There are no adjustments for height and width. Not all programs were shot on 16 x 9 wide screen resolution so it will leave the screen with black spaces . around the edges. Nothing wrong with the TV, and nothing you can do other than the zoom buttons you use now.
Aug 09, 2017 | Sanyo DP19648 19 in. LCD TV
My grandson has a rm 125. he is a little short. and I would like to lower the height of it. Is there a way to do this by adjusting the rear shock?Or do I have to change wheels and front end?
My son has raced for years, and every time he moved up a bike size and was a little small for it, I cut down the seat for him. It's actually pretty easy to do, and if you look closely a lot of pro's cut their seats as well. Remove the staples from the bottom of the seat and pull the cover off to expose the foam. I typically will mark the foam with a black marker, making a gradual curve from 0 to 2' down where his **** is and back to zero again at the rear. An electric carving knife works great, but a hacksaw blade will do a nice job as well. After cutting the height down, fold the seat cover at the seams, center it on top of the foam and trace the original width of the seat in black marker around the cover. Then taper the foam on each side back to it's original width. I then buff the knive marks out with a open rasp or a scotch brite pad. Restretch the cover from the middle first to both ends, an electric stapler works best with 5/16 staples. Trim the excess cover with a razor and your finished. Good luck!
Jun 09, 2011 | 2003 Suzuki RM 125
Which tags are use to adjust image in css as it remains same even we have to make small or big or whatever?
Its very simple. You have to use width and height attribute of <img> tag to adjust the image size in css.
for example
img.b46860 {/* scalable em size class 468px/60px banners */ width: 29.25em; /* replaces 468px width */ height: 3.8em; /* replaces 60px height */ }
Regards, polysandy
Jun 07, 2010 | Computers & Internet
Picture is out of line
One of the following may be misaligned. i) Aspect ratio of your TV may be wrongly selected. i.e. select 4:3 in place of 16:9 or vice versa with your Remote . ii) Picture Width or Height may be wrongly adjusted. With the help of Remote, select MENU go to PICTURE option, reduce height or width which ever is needed.
Have a nice day Rating the solution is highly appreciated.
Mar 07, 2010 | RCA HD52W58 52" TV
I have a roland vs-840ex and it keep saying no disk when i put one in there
Hi ,
I hope I can help you with your issue ,
the zip drive is either dirty or bad.
The zip drive has a drive spindle that could be not spinning correctly or the reading heads are bad.
Try a can of air to blow the dust out first.
or remove the drive and try cleaning the heads (not an easy job) .
here are the instructions for replacing the drive
linked
If I have helped you with your issue please click accept.
If you have more questions please post them
I will reply asap
Thanks
Eric
Sep 16, 2009 | Roland Vs-2000CD Digital Studio...
======== Exception Information
install Microsoft Runtime SDK 6.0 or up version first then run and install again your program.
Aug 10, 2009 | Systran Business Translator 6.0 Euro Full...
You Tube Videos:
part 1 of 2
part 2 0f 2
Mar 20, 2009 | Computers & Internet
Iacer 5520 lapptop screen won't come up to normal size
You to change the setting of your monitor that is found at the bottom of your monitor some near the power button (of your monitor when you turn on the monitor) it is a push botton where you can change the width, height, etc. not on the resolution or any program found in your computer.
Thanks
Nov 19, 2008 | Acer AL1717 17" LCD Monitor
Find the Price for cabinet door
If you dos program can support Structured Query Languange (SQL) that's possible to do it. example sql statement below:
SELECT * from Cabinet WHERE height='numeric' AND width='numeric' ORDER BY Height, Width
But since it doesn't work with your existing programming language, much better if you will migrate to GUI programming language such as Visual Basic, Visual C++.
Hoping for your kind approval to make my rate solved.
Best regards,
Philip
Nov 05, 2007 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
