Question about Electrolux E30EW85EPS Electric Kitchen Range
Electrolux double oven electric EW30EW65GB2 display not show all numbers
barkencoa
  • 3463 Answers
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Bottom oven on Electrolux EOU 6330
Probably a broken bake element.
Posted on Jul 05, 2009
  • 73 Answers
SOURCE: I have an Electrolux double oven and grill which
you didn't specify a model but most of the electrolux unit have a single control panel across the top behind the front control panel on the main circuit board is an object about the size of a dime with a small red button in the center apply firm presure to this red button it will click back into place (if that was the problem) its a thermal over load and is sometimes accidential tripped by trying to broil some thing in the top oven with the door open a little bit excess heat gets in behind the controls and pops the thermal WARNING turn off the power before attempting this the reset is mechcanical and does not need power to reset it ALSO lots of delicate stuff in there- ribon cabels -thermal coupling leads be careful
good luck
Posted on Sep 05, 2009
  • 195 Answers
SOURCE: Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Posted on Dec 06, 2011
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
Wall oven not heating
Hey friend, thank you for your post!
I understand that your Electrolux wall oven is not heating. I would like to ask some additional questions so that I can better assist you. First, is your appliance displaying an error code of any sort? Secondly, is display on? A step you could try would be to reset your appliance, which is done by either unplugging your appliance or flipping the household circuit breaker for ten minutes. I look forward to your response to better assist you. -Matt
Jul 28, 2014 | Electrolux EW30EW65SS Stainless Steel...
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
Electrolux 30" electric double oven
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Dec 31, 2010 | Ovens
I have an electrolux EOU 6330 double oven, how do I gain access to change a faulty element?
Assuming you live in the u/k, and it is an electric fan assisted oven, and that it is the fan oven you are referring to, then the element is usually to be found at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 10, 2009 | Electrolux EOU6330 Electric Double Oven
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Electrolux E30EW85EPS Electric Kitchen Range Logo
21 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
