Question about Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP)
Problem using Wa1003A and Tew 432 brp to share my internet
I am using Wa1003A adsl router to connect to internet. I configured it with pppoe usernames and password and able to connect to internet with a wire connected to my PC and no login is required as of now.
Now, I wanted to share my Internet connection between 2 pcs. For this is i am using trendnet tew 432 brp wireless router.
I followed the below configuration:
1.Configured WA1003A adsl router with pppoe connection and provided my username and password.
2. configured my TEW 432 brp a DHCP client or fixed ip mode. ANd enabled DHCP server on it.
3.Connected a lan wire from WA1003A to WAN port on TEW 432brp wireless router.
4.Connected my pc to TEW 432 brp with a lan wire to one of the 4 ports available on it.
Now, i am unable to browse any webpages. BUt my skype is logging in without any problem.
Can some one help me solving this problem. Please let me know how to configure properly to share my internet between 2 pcs.
( Are there any different type of lan wires should be used to connect ADSL router and Wireless router?)
Thanks in advance.
-Madan.
I connected it to WA1003A with a lan wire. A
  • 209 Answers
Lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Posted on Apr 26, 2009
NO PPPoE server found no internet connection
use Dynamic which is obtain ip address automatically
Oct 02, 2013 | Trendware TRENDnet TEW-435BRM 802.11g...
D-Link DSL-2750U N300 ADSL Modem Wireless Router configuration with Hathway
YES THATS TRUE. TO CONFIGURE THE ROUTER. NEED THE PPPOE USERNAME AND PASSWORD FROM THE INTERNET SERVICE PROVIDER. VPI AND VCI SETTINGS.
..THEN ACCESS THE ROUTER PAGE
..GO TO ADVANCE SETUP PAGE.
..THEN LAYER2 INTERFACE
..CLICK ADD
..CONFIGURE THE SETTINGS.
..POWER CYCLE THE NETWORK.
Nov 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I get my dsi connceted to the internet
The NetGear DG834G is an ADSL router. If you an ADSL internet connection, it should connect via PPPoE autentication.
This means that you must configure the username and password, on the router, provived by your internet service provider.
Please read the "Installing Your Router Using the Smart Wizard" section on the router's manual here ftp://downloads.netgear.com/files/DG834Gv5_SM_31Mar08.pdf and follow the steps.
Mar 12, 2011 | NetGear DG834G Router
How do i secure my router
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 02, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
My Trendnet router 423 BRP system lights is blinking. I sthere a problem?
The model number of the Product you are mentioning would be TEW-432BRP. The system light should be blinking all the time showing that the router is active. If the system light is Solid or off then there is some problem
Apr 06, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
How to connect the trend net tew-432 brp router to MT800 wired modem
MT-800 is is just an ADSL modem. The cable from the modem connects to the WAN port on the router. A second cable goes from one of the LAN ports to the computer(s).
Here is the secret - Press the reset on the router for ten seconds (one thousand, two thousand...) AFTER this, unplug the power from the modem for ten seconds and then plug the power back in. Do it in this order.
The first step clears the router and finds the computer.
The second step resets the modem and tells it to find the router.
Enjoy your Internet!
Mar 30, 2010 | Computers & Internet
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Modem to broadband router
Hi ditia,
U need to connect the modem>>router>>computer..u need to login to the router by using the ip address 192.168.1.1..it will prompt for a password...enter the password to login to the router..After logging in to the router..there will be a connection type..u need to select pppoe..after selecting pppoe u need to enter the user name and password which u got from ur ISP..save it...now ur internet will work...please give me a feedback if this info is useful
Jul 09, 2008 | D-Link DI-704P Router
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Help
Hi Sloan!
Go here and select your Tendnet version from the list. Click on the version. Read the instructions carefully, some updates have to be installe before others. Get up to the latest one, from 10.2007. Should fix your problem.
Good Luck!
Jan 06, 2008 | Trendware TEW-432BRP Wireless Router...
Open Questions:
See all Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Questions
Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP) Logo
762 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
