Question about General Electric GSH25JGDBB: ENERSTAR 25.3 Cu. Ft. Side-By-Side Refrigerator with Dispenser
GE GSH25GGCBBB COND FAN NOT RUNNING, COMPRESSOR NOT RUNNING
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
If the heater HAS shorted (burned look) it CAN destroy this board. FYI: Usually, heaters burn because the defrost termination thermostat is defective. The heater can literally melt the aluminum shield if this is the case.
ALSO: If your compressor won't run after replacing the heater and thermostat, WAIT for about an hour (with your fridge plugged in) before deciding this board is bad and preventing the compressor from coming on. Mine miraculously started...after 1.5 hours. YES.
It has a pair of freezer sensors (along with the simple defrost termination thermostat) with a microprocessor control that apparently brain fades sometimes.$$ saved.
Posted on Apr 02, 2017
4 Suggested Answers
SOURCE: Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Posted on Jun 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a GE refridgerator,
Check for a defrost problem.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located on the back . part 801 on this diagram. http://www.partselect.com/ModelFrames.aspx?ModelID=397572&ModelNum=pds22mcraww&ManufactureID=2&Selected=00124552i02&Position=0&mfg=GE&Type=Appliance&Mark=0
Posted on Mar 01, 2010
Sea Breeze
  • 4655 Answers
SOURCE: GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
WR55X10942 Main Control Board
Posted on Mar 22, 2013
My freezer has stopped freezing on my GE
sounds like the compressor has quit running or there is a Freon leak... either way it looks like a sealed system issue..... on some ge models if the cond fan motor quits it will heat up between the ref and fzr doors....
Oct 09, 2014 | Refrigerators
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
Fan and compressor not running
hi this sounds like your defrost timer is stuck on defrost,but if it is so then it should restart automatically.if it doesnt and it didnt defrost the ice either then it could be the heater;t/stat as well.i assume motor and cond/fan is off.if so try turning defrost timer manually first.good luck ali
Jul 04, 2012 | GE Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
The fan on my new GE Air Cond. will not stop
I opened and checked the online manual where I found the answer.
Nov 01, 2009 | GE Heating & Cooling
Fridge and freezer not working
need more info, is compressor in back of fridge running ?
is the evap coil inside freezer froze up ?
is the fan inside freezer running ?
is the cond coil under back of fridge in need of cleaning ?
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi I have a GE Fridge Model Number GTS18HBSW and it just started to make this loud noise. seems like it is coming from the fan or back of fridge only 3 years old. Any suggestions
Any noise in the fan needs to be corrected soon. It could be something trapped there or it could be something is wrong with the fan or the fan blades. To lose the operation of that fan will stop cooling and chance damage to the compressor from over heating. I recommend that you unplug and pull away from wall. Remove cover that covers compressor and fan and find what is causing this to prevent further damage. Let me know what you find and if you need additional help please let me know, Thanks, Sea Breeze
Aug 26, 2009 | GE GTS18HBSWW 28" 18.2 Cu. Ft. Top-Freezer...
Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
General Electric GSH25JGDBB: ENERSTAR 25.3 Cu. Ft. Side-By-Side Refrigerator with Dispenser Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
