Question about Mitsubishi WS-55807 TV
Mitsubishi WS55807 - sound / volume fluctuates
I have the TV since 2000 or 2001. It just happened yesterday that the TV's sound will become loud for a few seconds and then come down. The volume can not be controlled anymore. Out of 100 minutes of TV watching, the volume will come up and down for about 10 minutes of total time. Beside this problem, the TV will occasionally display some white lines cross the TV. The lines will stay for about 3 to 5 seconds. This only happened for about 1% of time.
    Genius:
  • 1,153 Answers
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. If this doesn't help you have to make some checks in set. First IC7D04 (temperature related) may cause lines in pic. Check 9v DC on terminal PCB at Connector JA pins 57&58 if missing then change IC9C25 part#270p677030 on signal PCB.
Posted on Sep 26, 2007
  • Lashawn Robinson Sep 28, 2007
    If this helps can you rate me so I can help someone else, Thanks!
SOURCE:
I just purchased the RCA RT2910 Theater System yesterday. When I hooked everything up, it was all working great. However, tonight when I was turned it on, all of the speakers were acting weird. They would...
What source(s)? Verify the speaker setup with the test tones to prove the hardware is all okay. Then go back and evaluate the conditions that create the problem. It could be an external cause.
Jun 01, 2011 | RCA RT2910 Theater System
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
MITSUBISHI WS55807 NO PICTURE HAVE SOUND AND CHANNELS
It may be the closed captioning it happened with mine. I simply turned off the CC on the TV.
Apr 08, 2010 | Televison & Video
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Got t7900`
I have had that problem with a T7700/T7900 speaker system.
Disconnect the remote control from the subwoofer. Then what you need to do is unscrew the remote volume/bass control unit (4 little screws). Swab the contacts on the volume dial with a cotton bud (q tip) denaturated alcohol or even perfume will work. Make sure you do it several times until all the slight dirt that is causing the volume fluctuation/spikes to happen. Also remove any remnants of cotton that might get stuck.Now you'll have it working as new as long do not cause any other damage to the unit.
Cheers,
Daniel
Jul 02, 2008 | Creative Labs Inspire T7900 Computer...
Loud popping and decrease in volume
I'm guessing power supply problems fluctuating, or main control board.
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Mitsubishi ws55807
does the menu show up?
Oct 31, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
