Question about VeriFone Omni 3700
I need a password for an omni 3750 which was changed by north american bankcard. I tried a few but to no avail.Any suggestions?
  • DT
    DT May 11, 2010
    Since there are a couple of passwords that can be changed on the machine we will need to know which you are trying to reset. Is it the Manager password that was changed? What function is requiring it?
I bought a used Verifone omni 3750 and it says download needed but it won't take any password we have tried. Is the machine just a gonner?
This unit is repairable. Change the battery and do the download needed to bring it back to factory reset. This will set you up for application download. Call Frank 775-338-6634
Aug 26, 2011 | VeriFone Omni 3700
I'm trying to reset the Group 1 password on my Verifone Omni 3750
The password on most vx510's can be reset by pulling battery and clearing RAM. Reassemble, clear Tamper and password will reset to original password (1aa66831). But if the certificate has been changed, only your download provider can help you. Call Frank @ 775-338-6634
Jun 08, 2011 | VeriFone Omni 3700
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
I have an Omni 3750 that I bought from a provider. I have since switched providers and now my Omni 3750 reads "download needed no *go variable". My previous provider gave me several passwords...
Here's Some that you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jan 19, 2011 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
Verifone omni 3750
Use this Master Password from the manufacture #23378463
May 02, 2008 | VeriFone Omni 3700
Retail Supplies Logo
1,021 people viewed this question
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
