Question about Refrigerators
Water draining from inside Fridge
Water draining from inside of frige
Check he drain line it might be blocked and leaking through a connection or broken line, when freezer goes into defrost, water has to go somewhere.
Posted on Apr 24, 2009
How do you fix running water inside the frige under vegi box?
clean the drain pipe at the back inside of the fridge
check small items ( peas or gunk) that is blocking the tube
Nov 03, 2015 | Refrigerators
Why do i keep getting a puddle of water in the bottom of my frige? The water must be coming from the top because each day, there is water on top of the food containers all the way down to the bottom.
Sounds like you have a defrost drain issue. Often times these get clogged, and the back flow water drips into the fridge, usually the culprit on a GE is a clogged drain diverter, located on the outside back of the unit. Remove the tube by bending and pulling away from the diverter while holding the diverter firmly in place. Then turn the diverter one quater turn clockwise and it should pull down and away from the appliance. Clean this diverter out thoroughly, as it is likely full of gunk. However, on some older model GE top mounts, ive seen the drain pan underneath the evaporator coil inside the freezer with a small rust hole, and the water drips through this hole instead of the intended drain hole, the water then misses the tubing, and drips into the fridge. this drain pan will then have to be replaced.
Dec 10, 2010 | GE Refrigerators
Water collects under bottom draws of frige
At the back of the fridge, inside, there should be a drip tray / channel which slopes towards the middle from both sides. At the middle you will find an outlet hole to the rear probably blocked. Clear with match or cocktail stick and the water drains away to an evaporation pad or container [often over the compressor]
Mar 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
I have an odor cause my fridge has been closed with no power
yes drain pan is located in the back on top the compressor....10:1 solution of water and bleach is good enough to clean it with....kills mold and mildew....also remember that if the fridge lost power and found cause a stench inside, could be held by the plastic....ive been using dryer sheets in my units to help with odors. may take a few weeks...but a new dryer sheet a week helps.
Jun 12, 2009 | Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water leak
the water is from your defrost cycle what is apening is that your drain tube is cloged you can bloe out the drain tube from behide the fridge or remove the small funel that is located inthe fridge part of your frige and clean it out that is wher they normally cloge some are screwed in some are that you pull out located in center top thanks from gilles
Mar 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Mar 14, 2009 | Kenmore Refrigerators
Water coming from somewhere inside my fridge
this is because your defrost drain tube at the funnel inside your fridge is clog your fridge defrost every 6 to 8 hours the water has to drain in a pan under te frige open the fridge door you will see above a small funell typy plastic tubing going tru the wass pull it out and clean every thing should be fine thanks from gilles
Mar 13, 2009 | Refrigerators
Fridge leaks
your drain is clogged,you need to get to the drain and use a hanger or shop vac to **** the clog out,let me know-mike
Jul 08, 2008 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
