Question about NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
Hoveround rear tire needs inflating
The read tire on my Hoveround needs inflating, but the valve is covered, and I don't see a way to get to it easily. Am I overlooking something?
This is the MPV model, only one rear tire, and it's covered by a fender like shield and has the parking brake lever on it.
    Novelist:
    Champion:
  • 232 Answers
I don't think you have an MPV4. That model has 2 rear caster tires that are solid and require no inflation. The front drive tires have a valve stem sticking out of the center rim that is easily accessible. Make sure your power chair is gray and says Hoveround on it.
Posted on Oct 01, 2010
When something goes shear through my tire; can that be patched up? Would I need to get a new tire if something causes a big enough hole? How are tire holes patched anyway? bryanflake1984| http://w
Do you have solid tires or inflatable tires. If they our inflatable tires and the hole is not too big they can hot patch them at a tire shop most of the time for free. If its a solid rubber tire and you have taken a big chuck out of it you will have to get a new. But I am thinking you have an inflatable tire. take it too the tire shop and see what they can do.
May 08, 2014 | NRS Hoveround MPV 5 - Used Power...
Rear tire hard to access valve stem
Hi Lou, sure do get a cycle jack. For around $100 includes shipping you can get a nice one. Please to visit website below:
Black Widow Motorcycle Jack Lift
Good luck
Feb 23, 2014 | 2008 Harley Davidson FLSTN Softail Deluxe
I changed 1 of my valve sensor so i need to no how to reset the tpms light
By operating the tire pressure warning reset switch, the tire pressure warning ECU can be set to issue a warning at an inflation pressure that corresponds to the standard pressure of tires .Therefore, you must set the warning threshold to the proper value in order to comply with the local regulations .Operate the tire pressure warning reset switch only after the inflation pressures of all tires have been adjusted on the vehicle.To initialize the system, press and hold the tire pres- sure warning reset switch for 3 seconds or longer with the ignition switch in the ON position. When the system receives the
initialization signal, the warning light blinks 3 times (1 second on, 1 second off). During initialization, the tire pressure warning valve and transmitter measures the inflation pres sure of the tire, and registers the signals that are transmitted into the tire pressure warning ECU at a frequency of once per minute. The initialization process is completed when signals from all the tires have been received. It takes a few minutes .
Tire size Inflation Front Inflation Rear
P 195/65 R15 89S 30 psi 30 psi
195/65 R15 91H
P 205 /55 R16 89H 32 32 psi
P 215/45 R17 87W
205/55 R16 91V
Dec 10, 2013 | 2010 Toyota Corolla 2.0
Hoveround chair only turns left
Do the casters swivel? If not, make them loose.
Are the tires properly inflated? If not, inflate them.
Does the silver post part of the joystick move up and down at all (if it does it's shot)
Has it been exposed to outside moisture? If so your motor brake may be ceased and needs to be disassembled and cleaned.
Hope this helped.
Oct 21, 2013 | Hoveround MPV5 Electric Wheelchair - Used...
The rear tires on my Everest & Jennings foldable wheelchair are very low in pressure. Both tires have the words "Inflate to 55 - 65 Pounds" clearly stamped on the sidewalls. However, there...
Your tire tubes may have been replaced with urethane foam inserts - these give a comfortable ride like air-filled tires but cannot go flat - would explain why you don't see a fill valve - these inserts fit inside the regular tire carcass.
If they are worn out, you'll need to replace them, process is same as replacing a tube.
Feb 20, 2011 | Everest & Jennings Advantage Manual...
Service tire monitor on what is the problem? how do you reset the system?
TIRE PRESSURE MONITOR SYSTEM
The Tire Pressure Monitor System (TPMS) uses radio and sensor technology to check tire pressure levels. If your vehicle has this feature, sensors are mounted on each tire and wheel assembly, except the spare tire. The TPMS sensors monitor the air pressure in your vehicle's tires and transmit tire pressure readings to a receiver located in the vehicle.
The TPMS is designed to alert the driver, if a low tire pressure condition exists. This system also allows the driver to check tire pressure levels using the Driver Information Center (DIC).
When a low tire pressure condition is detected, the TPMS displays the "CHECK TIRE PRESSURE" warning message on the DIC, and at the same time illuminates the low tire pressure warning symbol.
You may notice, during cooler weather conditions, that the tire pressure monitor light, located on the instrument panel cluster, and the "CHECK TIRE PRESSURE" message will appear when the vehicle is first started and then turn off as you start to drive the vehicle. This could be an early indicator that the tire pressures are getting low and need to be inflated to the proper pressure.
Each tire, including the spare (if provided), should be checked monthly when cold and inflated to the inflation pressure recommended by the vehicle manufacturer on the vehicle placard or tire inflation pressure label. (If your vehicle has tires of a different size than the size indicated on the vehicle placard or tire inflation pressure label, you should determine the proper inflation pressure for those tires.)
As an added safety feature, your vehicle has been equipped with a tire pressure monitoring system (TPMS) that illuminates a low tire pressure telltale when one or more of your tires is significantly under-inflated.
Accordingly, when the low tire pressure telltale illuminates, you should stop and check your tires as soon as possible, and inflate them to the proper pressure. Driving on a significantly under-inflated tire causes the tire to overheat and can lead to tire failure. Under-inflation also reduces fuel efficiency and tire tread life, and may affect the vehicle's handling and stopping ability.
Please note that the TPMS is not a substitute for proper tire maintenance, and it is the driver's responsibility to maintain correct tire pressure, even if under-inflation has not reached the level to trigger illumination of the TPMS low tire pressure telltale.
The "CHECK TIRE PRESSURE" warning message and low tire pressure light (telltale) will appear at each ignition cycle until the tires are inflated to the correct inflation pressure.
The Tire and Loading Information label (tire information placard) shows the size of your vehicle's original tires and the correct inflation pressure for your vehicle's tires when they are cold.
Your vehicle's TPMS can alert you about a low tire pressure condition but it does not replace normal tire maintenance.
NOTICE: Do not use a tire sealant if your vehicle has Tire Pressure Monitors. The liquid sealant can damage the tire pressure monitor sensors.
RESETTING THE TPMS IDENTIFICATION CODES
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. Each tire/wheel position is matched to a sensor, by increasing or decreasing the tire's air pressure. The sensors are matched to the tire/wheel positions in the following order: LF TIRE (left front tire on the driver's side of the vehicle), RF TIRE (right front tire on the passengers side of the vehicle), RR TIRE (right rear tire on the passengers side of the vehicle), and LR TIRE (left rear tire on the driver's side of the vehicle).
You will have one minute to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you will need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to "RUN" with the engine off.
  3. Turn the headlamp switch from "OFF" to the parking lamps setting four times within three seconds. A double horn chirp will sound and the TPMS low tire warning light will begin to flash. The double horn chirp and flashing TPMS warning light indicate that the TPMS matching process has started. The TPMS warning light should continue flashing throughout the matching procedure. The "SERVICE TIRE MONITOR" message will be displayed on the Driver Information Center (DIC).
  4. Start with the driver's side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, then stop and listen for a single horn chirp. The single horn chirp should sound within 15 seconds, confirming that the sensor identification code has been matched to this tire and wheel position. If you do not hear the confirming single horn chirp, you will need to start over with Step 1. To let air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage or a key.
  6. Proceed to the passenger's side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger's side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver's side rear tire, and repeat the procedure in Step 5.
  9. After hearing the confirming horn chirp for the left rear tire, check to see if the TPMS warning light is still flashing. If it is, turn the ignition switch to LOCK to exit the sensor matching process. If the TPMS warning light is not flashing, the five minute time limit has passed and you will need to start the process over beginning with Step 1.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems. The spare tire does not have a TPMS sensor. If you replace one of the road tires with the spare, the "CHECK TIRE PRESSURE" message will be displayed on the DIC screen. This message should go off once you re-install the road tire containing the TPMS sensor. The "SERVICE TIRE MONITOR" message is displayed when the TPMS is malfunctioning. One or more missing or inoperable TPMS sensors will cause the service tire monitor message to be displayed.
Nov 23, 2010 | 2006 GMC Yukon
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Aug 21, 2010 | Topeak Joe Blow Ace Floor Pump
Hoveround tires squeek / squelch something terrible on tile
Try tightening the nuts that hold the wheels onto the chair. Make sure they are very tight.
Dec 25, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
How much air do i need in my tires
the tire industry recommends 32-34 PSI in all 4 tires
Nov 12, 2009 | 1995 Toyota Camry
Location of rear heater blower on 2000 pont montana
i got the same van ill take 600 -500$ sk8er724@yahoo.com
Jan 07, 2009 | 2001 Pontiac Montana
NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
266 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
rey francis basa
rey francis basa
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
