Question about MSI WindPad 110W 10Inch Tablet Computer PC Notebook
Charging issue of msi winpad - MSI WindPad 110W 10Inch Tablet Computer PC Notebook
Msi charger
it's either computer connector problem, or charger connector cable problem, or broken cable, or broken charger, or loosen connection between wall cable and charger, or charger to wall cable, or battery problem.....
if it runs, but not charging, I assume it can be battery issue...
Feb 15, 2014 | Computers & Internet
My msi ex465 wont start up on battery mode only the power lead on , while on ac it does but i need to unplug for several times before it will do,,, i have done reformatting it for several times...hope...
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 28, 2012 | MSI EX465 Notebook
MSI CR420 battery not charging
sounds like the bat is already ruined or the power control on the motherboard is faulty
Aug 02, 2012 | MSI Cr420 Laptop Lcd Screen 14.0" Wxga Hd...
MSI Wind u100 - battery LED flashing red
check for an update with windows 7 then go online to asus support or call them. They should have a solution for you.
May 12, 2010 | MSI Wind U100-053US 10-Inch Mini Laptop
Msi u100 shuts down when power cord is removed. battery is fully charged. blue light on panel not coming on.
Sounds like a faulty battery. It's saying it's charged but obviously isn't. Best to check the battery contacts are clean first though obviously, otherwise try another battery.
Mar 01, 2010 | MSI Microstar U100053LA Notebook
Battery disabled
either the battery is defective, or the charging functionality of the laptop is not working. check for solutions for this from the manufacturer, it may be possible they are aware and have released a BIOS update to address this issue.
Jan 06, 2010 | MSI Wind U100-451US Notebook
My msi won't turn on. Battery is in, charged, and
Try unplugging it and removing the battery. Wait a few minutes. Yes actual minutes. Then put the battery back in and try again.
When you get back in try rolling back to a restore point when you know things were working well.
Could be a software update of some kind threw things out of whack.
Aug 11, 2009 | MSI Wind U100-004US Notebook
Battery overheating during recharge
It's very likely that your battery has malfunctioned. I would recommend buying a new one.
Jan 02, 2008 | MSI M510C Notebook
MSI WindPad 110W 10Inch Tablet Computer PC Notebook Logo
20 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
