Question about Freezers
Beko as920s I have a Beko Fridge / Freezer AS 920 S fault code 8 ?
jaylex
  • 417 Answers
SOURCE: BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Posted on Feb 16, 2008
SOURCE: I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Posted on Jun 24, 2009
SOURCE: BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Posted on Jul 01, 2009
SOURCE: fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Posted on Jul 09, 2009
  • 4793 Answers
SOURCE: beko frost free fridge freezer keeps icing up
if the freezer is in a cold place (below operating temp of freezer)the fan housing is the first to freeze.solution is move it to a warmer room.a common fault with freezers in garages.....
Posted on Feb 05, 2010
I have a BEKO CDA539F and notice that there is one with an X attached to the end of the code that is amongst the recall models. I asssume that my fridge freezer is safe. Am I correct?
From what I understand, you are safe if your serial number does not match the ones in the list exactly. That said, the information I have is from knowledgeable sources but NOT from BEKO, who have failed to answer their 0800 incident line or reply to my mails for 4 days now (By coincidence, while I provide a lot of technical help on this forum, I also have a BEKO fridge that IS on the list).
I would go to their site and send in a mail via the facility they offer there. I imagine that at some stage you will get a confirmation that all is OK with your fridge, but I would want to cover the bases if I was in your position. For convenience, the original article I wrote with the BEKO website listed in it is reproduced here for you:
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including most importantly, BEKO's own website, the MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
The fridges affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers indicate the year of manufacture, so if your serial number doesn't start 00, 01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
The site also provides a mail address and a UK Freefone number that you can call (Though I've tried the number and it keeps cutting me off!! I presume they are swamped with calls)
Jul 09, 2011 | Freezers
FREEZER DEPARTMENT IN A BEKO CS460FF
the hose out of the back of my fridge freezer is loose is this right and there is a bad oddur
Dec 09, 2009 | Freezers
Jun 18, 2009 | Freezers
My beko frost free fridge freezer is not switching on and off. it is running constantly and the fridge is now very cold on number 1 setting?
you would have to find out what temperature your freezer is. if it is reaching -20 then it should be cutting out and chances are the thermostat is stuffed
Apr 30, 2009 | Freezers
Apr 12, 2009 | Freezers
Beko fridge freezer
Is it froze up? maybe it needs defrosted.
Jan 19, 2008 | Freezers
BEKO FRIDGE FREEZER
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
85 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
