Question about Kyocera Copystar CS-1820 Black and White Copier
C6000 code service reset on fs1028mfp - Kyocera Copystar CS-1820 Black and White Copier
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: c6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 09, 2009
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 ยท Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
How to repair fixing unit of copier machine it replies Error C6000
Hi
I assume that your printer is a Kyocera Mita and probably one from their KM range. I proceed on this basis.
It is possible to reset this using U163 in Maintenance Mode to reset the code. If the error still persists it is to do with the fuser unit. I found many error codes for many printers and the particular page of relevance to you is here:
Error Codes Kyocera Mita KM2540 Code C6000
It is for the KM2540 but you can change models easily using the drop down menu in the centre of and near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Office Equipment & Supplies
How t reset fuser error c6000 for taskalfa 180
Fuser reset: Press 'system menu/counter' key, select 'service setting', then while pressing 'start' and '#', press 'enter'. Select 'Maintenance mode', then press 'enter'. Enter '163' using the up/down keys, then press 'enter'. Turn machine off to exit Maintenance mode. C6000 indicates fuser did not come up to temp in the allotted time; you 'may' have a bad heater lamp if code reappears. Good luck.........
Thanks,
Sep 05, 2014 | Office Equipment & Supplies
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Aug 23, 2014 | Kyocera Mita KM-2050 Printer
ERROR CODE C6000 ON OLIVETTI D-COPIER 200MF
C6000 is usually cause by fluctuation of current(power supply).
STEP 1:
Open top cover then turn ON the machine,press System Menu then scroll down to Service Setting,then HOLD BOTH the "Start key" and "#" and press "OK".
Scroll down to Maintenance Mode then press "OK".
press 163 on the keypad
scroll down to "Execute"
press "OK"
Turn Off/On...
If C6000 appears again..,
STEP 2:
U have to reset the fuser thermostat manually.
FUSER REMOVAL:Remove rear cover,top cover,left and right cover.
Remove two screws. Unplug two connectors. Pull out Fuser unit.
Thermostat removal:
remove two screws,separate the upper part from the lower part,,
remove separation claws (3pcs each 1 held w/ screws at the rear)
remove the heater lamp,and upper fuser roller...
remove two screws that held the thermostat (circular shape)
(reset manually)
If you touch the top of the thermostat you will notice that it is in concave form...,you have to drop it hard on the flat surface in order to bring back it\'s original form which is CONVEX.
DO THE REVERSE ORDER TO ASSEMBLE.
THEN,Repeat procedure in STEP 1.
Mar 03, 2014 | Kyocera Copystar CS-1620 Black and White...
Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Feb 18, 2010 | Kyocera Mita KM-5035 Printer
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
C6000 error code
Hi
press enter
press enter
select execute
press enter
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Copystar cs1815 c6000 code
This is a fuser problem -- here is a reset method:
press enter
press enter
select execute
press enter
Aug 18, 2008 | Copystar CS-1815 Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
90 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
