Question about LG LFC20760 Bottom Freezer French Door Refrigerator
Door latch assembly lg model lfc20760 replacement
2 Suggested Answers
SOURCE: door won't latch on lg model LD2120wh
je cherche la télécommande de LG DR-4912V
Posted on Dec 24, 2009
My LG refrigerator gives beep continuously, need urgent solution
check if the thread here can help.
Note the Test Mode: LFC23760 / LFC20760 / LBC20514 / LFC20740 / LFC22740 / LRBN20512 Category: Refrigerators -> French Door -> Test Mode LG LFC20740 Refrigerator constantly beeping and fridge not cooling
May 13, 2016 | LG Refrigerators
Washer door latch
Unplug your machine, remove the top panel, doublecheck all of the wiring is securley connected. Sometimes the wiring becomes loose due to the machine's vibration.
Jun 24, 2008 | LG WM-1832C Front Load Washer
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
Door will not lock .what do I need to replace .?
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
It can also be a defective main control board, but this is not common.
Feb 20, 2015 | LG Washing Machines
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
DE error is coming on my LG wf-t90z20
"dE" means you have a door latch error. If you've already tried to unplug the machine and that didn't correct the issue, the door latch assembly will need to be ordered and replaced to fix the issue. The latch assembly is just not reading that the door is shut properly even though it is.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2011 | LG WM-2277HW Front Load Washer
We have an LG top load model WF-T7012EN. All of a sudden it would stop and dE message will be displayed. If you try to start it again, the same scenario will happen. We had tried to level the load and...
dE indicates a door lock error. Turn off and then unplug the washer to reset the machine. Press and hold the Start/Pause button button for 5-10 seconds. Connect the power cord. Turn on the washer. Open and close the lid to see if it closes properly. Try to run the washer through a cycle.
On some LG top-loading machines, the error is simple to fix. These LG top loaders used a magnet in the front of the lid that to be in place to trigger the lock. When the magnet breaks off or is misplaced, the dE error will occur. If you find the magnet in the washer, replace it in the lid. If you don't see the magnet, get another one. Keep the magnet in place with duct tape.
On other LG washers, the problem is the door not being aligned with the lock, the lock assembly or the electronic control not getting the lock message. Make sure that the lid is closing properly. Bent hinges can cause the issue. Check the latch assembly and the wiring between the latch and the control board. To check the latch assembly, you may need to remove it from the washer. Check the circuit with a multi-meter to ensure that the switch gets power. Replace either if faulty. If the latch assembly and wiring are good, then the control board may need to be replaced.
I hope this helps.
Jan 12, 2018 | LG Washing Machines
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
LG LFC20760 Bottom Freezer French Door Refrigerator Logo
43 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
