Question about HP A500N PC Desktop
Pc didn't start,flashinh green light in the back..I disconnect all inside and the green light is solid now,.How I can check my motherboard?
A500n didn't turn on,green light flashin in the back of pc (power supply).I remove all the components and light is solid green?How i can check my motherboard.. Tks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
If you can get another power supply unit then you can try that first. Usually when the condition you describe happens it is either the motherboard or Power Supply. If you replace it with another PSU then you have to have at least the same or greater output watts.
Posted on Apr 24, 2009
  • computerscot Apr 24, 2009
    Remeber a bad PSU does not always mean no power. It can provide some power, but just not enough to start the computer.
Motherboard aux power light is flashing
If you mean the power button just flashes green but it does not power on then your motherboard might be the issue. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. In other words just have the power supply and motherboard connected and see if the power light stays solid green. If it does then start re-inserting cards and connecting drives etc (WITH POWER DISCONNECTED) to try and isolate the problem. If not then your motherboard is probably defective and needs to be replaced. Also plug the computer directly into the AC wall outlet.
Nov 16, 2012 | Dell Dimension E521 PC Desktop
Vaio desktop blinking power supply
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector and next to a green blinking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
If the steps above don't work you will need to get a new power supply.
May 19, 2012 | Sony VAIO VGC-RB42G PC Desktop
Cant find speaker outlet
The correct mini jack on the back of the computer for stero is the light green mini jack.
Feb 17, 2012 | HP A500N PC Desktop
Power supply or motherboard problem?
Hi talissap,
The blinking light is telling you something about the PSU. First check any AC mains voltage select switches for proper setting. US should be 115. Second if you have a multimeter, you could test the PSU for voltage. Disconnect all power to all components. remove all components from the board including cpu, memory . Leave the PSU only plugged into the board. Press power. If the fan turns on then it's not the power supply. The brand power supply isn't the best, I've seen where you need to wait for 5-20 minutes for the blinking to stop, at which time it will fire up. Now, if it doesn't power up, then it's most likely the PSU.
Good Luck,
Mark
Dec 08, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
HP won't power on at all~PSU light blinking, then solid, then off
Dead short on the machine causing the power supply to go into shutdown (Fold Back Protection)
Remove all of the connectors coming from the power supply (Label them so that you know here they go back to on the Motherboard and the DVD etc (Including the processor fan one)
Place all of them back one at a time starting with the main one if the led stays on then plug in another till you locate the short.
If the led dies when you plug in the main MB connector then you are in deep brown stuff
All you can do then is to remove the Ram and any other unpluggable device to see if that is the cause
Jul 05, 2009 | HP PAVILION A6230N DESKTOP PC
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
HP A500N  PC Desktop Logo
90 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
