Question about HP PSC 2175 All-In-One InkJet Printer
Scanner stopped working
I have an hp psc 2175v all-in-one. For some reason the scanner will no longer work. When you click on scan the select device box is empty. But both the printer and the copier functions still work. I am running Windows XP Home Edition. It has always worked with no problems. Any suggestions or help would be appreciated. Donna
    President:
  • HP Master
  • 1,996 Answers
Please have a look at this article available from HP"s excellent online support site. If that doesn't seem appropiate, then see here or enter the exact error message you are getting into the search bar.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 24, 2009
Scanner isn't working with scan button. How do I manually scan using computer?
Go to start (bottom left of main windows desktop), then programmes, then accessories and select 'paint'. Then within 'paint' go to 'file' and select the option 'from scanner or camera'. Select HP printer, which hopefully is an option, then follow on screen directions......
Mine stopped scanning when I bought a new Vista PC. Apparently the drivers won't run the scanner in the old way - but hopefully this'll work for you.
Jun 16, 2010 | HP PSC 1350v All-In-One InkJet Printer
How do I get the scanner in my HP Psc 1315 to work
You can scan with out any HP software also using the below steps.
Make sure that the printer is connected to the computer perform the following steps;
Steps for scanning in Windows XP: 1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Steps for scanning in Windows vista:
1.Click the Start (Windows) icon.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan.
Sep 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Jan 13, 2009 | HP PSC 1210v All-In-One InkJet Printer
Hp psc 1100/1200 all-in-one does not scan with vista..
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
Aug 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Do not know how to use scanner
If you have install HP s/w photosmart essential, you can scan material into coputer by selecting the get image function then select from scanner. A window will pop up. In which you can change the scanner parameter setup or accept the pre-scan quality and do the scan right away. Another method is in printer and fax folder, you can find the icon for scanner is located here too. Just click on the icon for scanner then you can get the scan result too. Hope this can help you.
Jun 23, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1110 all-in-one does not scan with windows vistas. I do not want to use ms paint is there any other soluion
I had this problem. If you like my solution please consider making a small contribution (e.g. 1$) to a charity of your choice.
For use on Windows Vista
Launch "Windows Photo Gallery", click on file and select "Import from camera or scanner". If your scanner is connected and powered up, your device(e.g Hp psc 1110) should be displayed in the "Scanners and Camera" section. Double click on your scanner in this window. A dialog box should be displayed. It will allow you to set scan characteristics and preview your scan. happy scanning !!
As far as i know "HP Director" has been replaced on Vista with the method described above.
Mar 26, 2008 | Office Equipment & Supplies
Scanner not working
I understand that you are unable to scan after upgrading the compuer from ME to XP.
Please follow the below given instructions to resolve the issue.
Check for the communication between the computer and the printer as scanning needs bidirectional communication unlike printing.
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are unable to scan using WIA, confirms that the issue is with USB drivers, please follow the below given instructions to refresh USB drivers:
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key, this will display the Windows Startup menu.
4. Select Safe mode.
5. After Windows loads in Safe mode, right-click the My Computer icon and select Properties.
6. Select the Hardware tab and click the Device Manager button.
7. In the Device Manager Window, double-click the Universal Serial Bus controllers.
8. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
9. Click OK to confirm the removal of the device.
NOTE: Repeat steps 8 and 9 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled.
Now, restart the system. The system automatically detects and reinstalls the USB port.
Then try scanning from WIA and if that works try scanning from HP Director.
Please click on Start>>Programs>>HP>>HP Director.
If unable to scan from HP Director, search for the file " hpqscnvw " in C Drive which is the executable file for Scanning.
Double click on My Computer to open it > C Drive > Programs files > HP or Hewlett Packard > Digital Imaging > Bin Folder. Check for the file " hpqscnvw " there.
If found double click on the file to and try scanning. You can also save the short cut of the file to desktop and can use that file for scanning.
Run the scan diagnostic utility to resolve the issue.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=oj-45265-1
ScanDiagnosticUtility_ver_1.5.exe
Just copy and paste the entire link into the Internet browser's address bar and press enter
If you are able to scan from computer, then follow the instructions from the below given article to scan from the printer front panel.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00503569&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Jan 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Won't scan
You have to go to Windows Photo Gallery. Click on "File". Select "Import" and it will prompt you from there
Dec 31, 2007 | HP PSC 2410 All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Okay It is probably a driver issue, to solve this follow this: 1. Right-Click the "MY COMPUTER" icon on the desktop. 2. Select "MANAGE" 3. In the window that pops up, find the option "DEVICE MANAGER" in the left window pane and select it. 4. In the main window browse down the list of devices until you come to "IMAGING DEVICES", expand it and see if your scanner is there. 5. If it is not there you need to install it as well as check any cables connecting it if it is there but has a yellow triangle with either an '!' or '?' covering it< you need to download the drivers from HP 6. If you do indeed need the drivers for your scanner here is a link to the drivers for your scanner just copy and past the link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441115&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us Just select your operating system and download and install the file on the page that follows Good Luck i hope this helps! Tyler
Sep 19, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
160 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
