Question about Aspire Digital AD-8000 DVD Recorder
Want to record from dvr - Aspire Digital AD-8000 DVD Recorder
DVR-R10 stops recording with 10-15 mins left
If it's your cable box DVR, you need to call your cable provider to reset your cable box.
Apr 16, 2014 | Directv R10 TV Receivers and DVRs
Trying to connect Archs DVR snap on to LCD TV and record
As far as i am aware you cannot record directly from the tv using a dvr snap on to record from the tv you would need the dvr station.
Dec 28, 2009 | Archos 5 Internet Media Tablet
Dvr is programmed but at times "chooses" not to record show and other times it does record
Be sure that a DVR timer is set to fire, instead of an auto tune. Also if it is a series then make sure you select new episodes, your dvr will not recor a program if it has already recorded the same program once, ( re run) you can also check your scehdule in your dvr to check if timer has been deleted or modified.
Nov 13, 2009 | DISH Network DVR 510 DTV Receiver /...
Sigma DVR 100
i can't find software driver for SIGMA DVR100 dictaphone?
please help
Aug 25, 2009 | Hitachi DVR-100 Digital Voice Recorder
How to record from DVR on Centrios EDW8020 Digital recorder
am new I dont have the manual I need to know how to record I bought the dvr+r disc but its not doing any thing
Mar 12, 2009 | Centrios EDW8020 DVD Recorder
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Record DVDs frrom Cable box DVR
Buy a recorder that records both +/-R and double layer disks.
I haven't seen a Comcast dvr but you should connect it to the svideo out port of the dvr to the svideo in of the recorder and the audio out to the audio in. If the Comcast doesn't have svideo use the video ports instead
Dec 20, 2007 | Cyberhome DVD Recorder - DVR1600
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
Aspire Digital AD-8000 DVD Recorder Logo
15 people viewed this question
Top Aspire Digital Televison & Video Experts
Josh Whitehead
Josh Whitehead
Jerry Kramer
Jerry Kramer
Are you an Aspire Digital Televison and Video Expert? Answer questions, earn points and help others
