Question about Viking Refrigerators
My new Viking d3 refrigerator does not make ice.
4 Suggested Answers
SOURCE: Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Posted on Sep 28, 2008
woodchuck789
  • 4070 Answers
SOURCE: Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 05, 2009
  • 10865 Answers
SOURCE: viking refrigerator DFSB423D
Hi. Sometimes the ice molds loose their lubrication and fail to release. To improve this, warm up the ice mold area with a hair blow dryer until the cubes release. Then dry the area and spray some PAM no stick food spray into the molds. This will lubricate the molds for several weeks. Joe
Posted on Sep 18, 2010
Viking built-in refrigerator/freezer:tube that fills the icemaker is freezing, so ice maker not working. Tech says because hooked up to RO, advised up pressure to 50. Of note, non-factory ice maker
The reason the fill tube freezes up is because the water valve is leaking by. 50PSI should be enough pressure. You most likely need a water valve.
Feb 01, 2016 | Viking Refrigerators
Viking Frig ice maker
Depends how old the Viking is?
Older Vikings with icemakers with a arm on the side, simply lift
the arm up until locks.
Newer Vikings with Electronic Controls look for a "slide switch"
mounted on the right side of front interior trim. You will see a
red led light usually blinking on and off near the slide.
Feb 19, 2015 | Viking DFSB483 Side by Side Refrigerator
Where is the ice maker control on the Viking 2005 regrigerator
I've maker arm above bucket . 2005, thr bucket can overfill that unless the shelf is in place. There is a new ice maker and arm assy which will help that in the future . Hope this helps
May 24, 2014 | Viking VCSB423 Side by Side Refrigerator
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
Viking side by side makes very little ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Apr 09, 2010 | Viking VCSB423 Side by Side Refrigerator
Ice maker on a viking side by side not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghd65
Mar 21, 2010 | Viking VCSB423 Side by Side Refrigerator
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Jan 06, 2009 | Viking Refrigerators
Viking beeping
do you notice alot of ice builup on the freezer back wall? if so you need to defrost it and more than likely replace the defrost terminator. make sure you remove the back panel and use boiling hot water to remove the ice( i normally use a coffee cup) part # 10442407 ONLY USE VIKING PARTS) others may tell you to use whirlpool or some other but DON'T
Mar 29, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
