Question about Dometic Rooftop RV Air Conditioner
My Dometic rooftop A/C does not run at all - fan or compressor. What can I check? Does the 12v system have anything to do with it running?
  • Dometic Master
  • 6,674 Answers
Yes, possibly, if you have wall thermostat. If controls are all at ceiling/manually, then 120VAC power should be all you need. If wall thermostat, you will require 12 VDC, or 24 volt transformer system for it to operate. Usually towables have 12 volt, and park models etc, use a 24 volt transformer in the system. If you hear clicking when trying to run it, on off etc, check 120VAC source, such as breaker wiring to it .
Posted on Nov 29, 2013
  • 127 Answers
SOURCE: Compressor doesnt come on in a dometic duotherm
If this is a wall thermostat controlled unit, then check to make sure that you have power coming from the yellow wire on the thermostat when it is placed in the Cool/Auto High mode. If you do not have power at the yellow wire, then you have a bad thermostat. If you do have power, then remove the control unit from the inside of the AC and see if you have power at the Y terminal there. If so, when you turn the thermostat to cool, can you hear a relay clicking in the box? If not, then you have a bad control box. If the relay is clicking, you need to check the power at the compressor relay on the board. It has a black wire to one side and a purple (or blue) wire on the outgoing side. Check to see if you have 120V on the blue wire when the tstat is set to High/Cool. If not, then you need to bypass the freeze switch to make sure that is not the problem. If you do, then you need to go upstairs and check the start capacitor for OK. It is located in the side compartment of the upper unit, it has a small black relay on the top called a PTCR. These often burn out and will cause the compressor not to work. If that is fine, then you go to the top of the compressor to the thermal overload switch. See if you have power at both sides, if so, then you have a bad compressor. If not, then the overload switch is open and not allowing power to the compressor.
Posted on Jul 04, 2009
22yooper
  • 828 Answers
SOURCE: Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Posted on Jul 18, 2008
SOURCE: I have my dometic Rooftop AC unit. The
Let it cool off.Install a hard start kit on the run capicator.Its only 2 wires & easy to put on.It should kick over.
Posted on Mar 16, 2010
motor1258
  • 6674 Answers
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
Posted on May 09, 2010
  • 397 Answers
SOURCE: 3+ year old 15K rooftop
It sounds like a short in the fan motor windings. The fan will remain free if that's the case, but it will not operate and will trip the breaker.
Posted on Jun 30, 2011
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Dometic rv ac fan does not run compressor does
fan relay bad ,bad capacitor cable between t-stat and relay module not making good contact.
Apr 11, 2013 | Dometic Rooftop RV Air Conditioner
I have a springdale travel trailer with a dometic ac system. When I turn the air on, with the fan in the auto position on the thermostst, the compressor turns on and runs, but the fan does not. The...
Neither.
The fan should run in the 'auto' position.
If it runs (on hi and lo settings) then I doubt if anything is wrong with the fan motor.
I would think your thermostat is bad and needs replacing.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Duo-Therm BRISKAIR on rooftop of houseboat runs, not putting out cold air. Also, fan doesn't seem to be running at top speed
Sometimes a weak capacitor will make a motor run slower so I would check that first. Also make sure the compressor is running. Let me know what you find. You may need to get the refrigerant charge checked too. By the way it may use the same capacitor for the fan and compressor.
May 26, 2010 | Dometic Rooftop RV Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
May 09, 2010 | Dometic Rooftop RV Air Conditioner
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
562 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
