Question about Garden
How do i fix spark plug cable
My 009 stihl sparkplug cable broke
    Problem Solver:
  • 5 Answers
If it broke at the end you should be able to pull the spring out of the boot and reconnect if it broke close to the coil it will have to be replaced
Posted on Oct 16, 2013
  • David Davtyan Oct 23, 2013
    Thank you it worked
4 Suggested Answers
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
  • 3 Answers
SOURCE: need a parts list or schematic
send me an email chainsawguy@frontier.com
Posted on Oct 28, 2010
please provide more info about saw! Your question leaves everything from stuck in a Bee tree to out of Gas. Got your mind on you saw and left a little info out about the saw, it happens. I was put on my first one at 10 yrs old and have used one every year since, i'm 63. Lets fix that Saw!
Gillight
Posted on Jun 22, 2012
Stihl ts400 no spark even after fitting new coil
I think if you have ordered a new ignition coil without give-up the serialnumber and year of build of the engine as the most important cause in this kind of disappointments because often there can be made a modification on the coil AND flywheel. both on new models and even the sparkplug changed for better heat degree
Some sellers have are not interesting and often do not know about it themselves, but giving the details on forehand there shall be a book opened. in the differences about modifications.
By themselves they do not usually, as long as it sells, because marketing technical based modifications are common on much technical tools and instruments.
Comparable the different revisions by bios on computer mainboards and software
If the right sparkplug and coil and the right flywheel are used then its impossible it will not function IF THERE IS NO PROBLEM WITH THE ' on / off ' SWITCH ...
Mar 10, 2017 | Stihl Saws
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
311y spark plug removal
3 long torx screws first to remove and remove the cap and the the next spark plug connector pull it of and use a spark plug wrench to remove the sparkplug .
Jan 16, 2016 | Stihl 311y
Stihl fs 120 brush cutter. I have renewed the coil and plug still no spark.
check the HT lead to the plug, slide the rubber cap back on the cable and see if the hooked connection is still in the cable. Check on/off switch and switch cables to the ignition module. (Illustration D- item 27)
http://www.mediafire.com/view/s3t41wajs772p46
Aug 24, 2015 | Stihl Garden
Stijl brush cutter spark plug gap
buy a new sparkplug
dont bother with the gap
if it wont run its usually fuel related
prob a leef in the tank or a blocked filter or carborator jet
Mar 06, 2014 | Stihl Br420, Br400, Br340, Br320 Back Pack...
No pilcoming through 009 stihl chainsaw
Check to make sure the pick up line in the tank hasn't come lose. Then check the port under the bar and cover is free and clear of debris. If that's not it you probably need a new pump.
Jan 29, 2014 | Stihl Garden
Stihl 009 chainsaw
Gillight
Jun 22, 2012 | Stihl Chainsaw 009-200T (30LP-50)
1978 YAMAHA RD400E NO SPARK ON ONE CYLINDER BIKE RUNS ON
Remove both sparkplugs from engine. Plug them back in the sparkplug cables and let them rest on the engine.
Make sure your battery is well charged.
Check for sparks while kick-starting...
Interchange the sparkplugs in the cables:
-Same plug give sparks: replace the spark plugs.
-Same side of engine sparks: interchange the low-voltage connector at the ignition coils.
Give it a try:
Same engine side sparks: Replace the defective ignition coil.
Other side of the engine sparks: Check the circuit harness for loose connectors, and/or Clean-replace the breaker points ( left side of the engine carter ).
Aug 28, 2009 | Yamaha RD 350 Motorcycles
Stihl chainsaw won't start
Put in a new sparkplug.
Jul 15, 2009 | Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
