A privilege sensation 75 washing machine, it washes half way(till rinse) and stops and then start showing E20 please what do you think might be the problem. thanks."
SOURCE: washing machine
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
rohityadav79@gmail.cm
Posted on Feb 03, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
torres No9
  • 27 Answers
SOURCE: Hi , I have an elctrolux washing machine, and it
E20 is difficulties in draining for washing. which can be drain tube kinked or blocked, drain filter clogged or dirty or the pump impeller behind filter is getting jammed by a coin or cotton or anything wrapped around it, remove filter and look at back of hole and see if impeller will turn use a long screwdriver to turn it, obviously with the power off
Posted on Jun 25, 2010
Testimonial: "Thanks"
rickead1
  • 1998 Answers
SOURCE: error E20 coming up on washing machine and wont
DEFINITELY a draining error - you need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out. DON'T call for a service - they will not tell you, but E20 codes are NOT covered and they will charge you for the call out! please remember to rank how this post helped and if i can answer any more questions please write back thanks again
rickead1
Posted on Aug 17, 2010
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
Hello My aeg l12700vit wash machine displaing E20 and dont rinse the loundry on the cottons program ,but on delicate program is running well.Please could you tell me what is the problem and how i can...
I think the outlet hose or filter or pump is blocked and it cant drain in time. Clean the filter and check if the machine drains ok by putting it on a rinse cycle.
I hope that helps
Jan 25, 2011 | Washing Machines
Washer won't finish wash cycle
e20 on a lot of machines will generally indicate a water emptying problem. Possible solutions: kink in the outflow pipe, internal blockage which is letting the water away too slowly, pump not functioning each of these needs to be checked.
May 24, 2010 | Frigidaire GLTF2940ES Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
ZWD1480W - the cycle will not complete when i programme it for a wash. Half way through the cycle it stops. The drum remains full of half washed clothes and will not even respond to spin or rinse. I have...
Thanks for replying. I was able to solve the problem by clearing the filter and draining the samll tube beside it. I was unaware that the filter needs to be cleared regularly.
Jan 11, 2010 | Zanussi ZWD1480W Front Load Washer / Dryer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
