Question about Panasonic RR-US395 Digital Voice Recorder
I need to erase the files
I dont know how to erase the files and the recorder is already full
Select the file you need to erase by scrolling through the numbers with the << and >> buttons. When you've reached the right file, press and hold the "erase" button. Once a screen comes up with a flashing trashcan and the file number, press "erase" again to complete the process. If you picked the wrong file here, press "stop" or any other button to cancel it before you hit "erase" for the second time."
Posted on Oct 28, 2007
Normally, hold down the erase button until the folder begins blinking, then release the button and press it again. You will have to do this for each file in the folder.
Posted on Sep 29, 2007
SOURCE:
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Cant delete folders
You can delete a file by
1.push menu
2.select folder
3.select file
4.press erase once and "delete" will blink on screen
5.press and hold erase to confirm deleting (or press stop to cancel)
Erase All Folders
1.select folder
2.press erase once and "delete" will blink on screen
3.press and hold record for 2 secs.(Folder/All/Delete will flash at the same time)
4.press and hold erase for 2 secs. again to confirm delete
If you want to erase all the files in a particular folder will leaving other folders files intact.
1.select folder
2.press forward repeatedly until "All" appears on screen
3.press erase-"Delete" will blink on screen
4.Press and hold erase for 2 secs. and all files in that folder will be deleted
good luck
Apr 08, 2009 | RCA RP5012 Digital Voice Recorder
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
Unable to delete files from the recorder
Resetting the Recorder (CLEAR)
This function resets the current time and other settings to their initial
status. It is useful if you are having problems with the recorder, or if you
want to erase the entire memory of the recorder.
1 Hold the STOP button, and hold the ERASE button for 3
seconds or longer.
2 Press the FF or REW button to select the “YES”.
3 Press the PLAY button.
Jan 14, 2009 | Olympus VN-2100PC Digital Voice Recorder
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
"Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
Oct 15, 2008 | Olympus DS-2300 Digital Voice Recorder
Please reread my problem
I have posted a new solution to your problem under the original question, please click on the link below to view it
http://www.fixya.com/support/t489138-olympus_ds_30_recorder_memory_full_but
Thank you
How to erase recordings on the Panasonic RR-US500
I called the Future Shop where I bought the recorder and the salesman looked at the manual online and saw that the Delete instructions do not tell you what you need to know.
To Erase or Delete recordings from this recorder, you have to select the track or file you want to erase, hit the Erase button, see that track number flashing THEN hold the Erase button down for a full second.
You can toggle until ALL comes up and then erase all your files at once if you wish.
You can also hit the Erase button first and then select the track you want recorded. The important thing to know is that you then have to see the number flashing THEN hold the Erase button down for a full second.
Mar 29, 2008 | Panasonic RR-US500
Deleting Files
1. Select folder (A/B/C/D)
2. Select file.
3. Press ERASE once and DELETE will
blink on the screen.
4. Press and hold ERASE for 3 seconds
to confirm deleting. (or press STOP to
cancel erasing file)
Aug 04, 2007 | RCA RP5015 Digital Voice Recorder
Panasonic RR-US395 Digital Voice Recorder Logo
127 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
