Whirlpool duet sport wfw8300swo2
Machine will not power up. When you plug machine in there is no clicking sound, no lights nothing
SOURCE: Whirlpool Duet Sport Washer will not drain - F-21 error
Perfect! Yes, they aer 1/4" 6pt screws. I didn't have to lift my washer, but the previous tech had put in 1 screw crooked, so that was FUN! I had cut out an opening on an old cracked tote and was able to hold all the water as long as I transferred some to a bunch of tupperware. Make sure you line up the upper mark on the white drain plug before putting back in. The tote was getting overloaded and I didn't notice the alignment marks until after having some water overflow. Just a heads-up if anyone has an emergency and HAS to get the plug back in in a hurry.
I found:
Wife's Victoria's Secret panties
2 dimes
4 pennies
some legos
a metal nut
pencil eraser
wall anchor
some legos
Posted on Jun 30, 2008
SOURCE: Whirlpool Duet Sport Error Codes?
My machine had the F21 code and the inlet to the pump was blocked with change, bobby pins, small rocks, pieces of fuzz and clothing. Removed the front cover of the mahine and removed the cap on the front side of the pump and cleaned this trap area out. The pump motor quit humming and the machine worked like it is supposed to!
Thanks
Posted on Sep 09, 2009
VtToolMan
  • 704 Answers
SOURCE: Duet Sport WFW8300SW01
This is a pretty easy repair to do and all you need to do is open up the door and go around the outer lip of the bellows gasket and find the retaining loop that holds the front edge onto the front cabinet panel. Look for the locking loop and carefully remove it. I find that a couple of pairs of small needle nose pliers work well, just be careful not to bend the retaining wire loop, as you'll need to reuse this when you put the new bellows gasket on.
Here's a line drawing that shows your washer model and the parts involved, to help make this a bit easier to understand and so you can see what you're going to do.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=DOOR%20AND%20LATCH%20PARTS&documentId=W0607261&backToLink=Return%20to%20subcomponent%20list
Once you've got the outer lip retainer off, you'll be able to roll back the gasket off the front panel mounting lip and get to the rear hose clamp. It's basically a giant diameter hose clamp like you'd find on your car's radiator, etc. You'll need a small socket or nut driver to remove this clamp (usually it's either a 1/4" or 5/16" but sometimes it's a larger 3/8" size.
Loosen it and remove it carefully and you can now remove the entire bellows gasket.
When you go to install the new one, you'll want to make sure that you line up the water inlet section properly (if your's has this design, so do, some don't). Be careful not to rip or tear the gasket when putting it on the outer tub and when you tighten up the clamp. Take your time and don't rush this, as you don't want to be doing it again, as these gaskets aren't cheap!
Once you've got the rear of the gasket on, you can then carefully and gently start pulling the front lip onto and over the outer front cabinet. It helps to have help in holding the starting point onto the lip while you continue installing the rest of the bellows gasket onto the cabinet lip.
Once you've got the entire gasket on the front cabinet and you're sure it's on the lip all the way around the panel. You can then reinstall the retaining wire loop.
Now you're done and can give it a try, as you've just likely saved yourself about another $150-175 bill by not having to have a service tech come out and do the job for you!
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
  • 662 Answers
SOURCE: Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: how can I repair code F24 on whirlpool duet sport ...
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Posted on Sep 28, 2010
My whirlpool duet sport front load (HT) washer is not working.
it sounds since this machine was named "duel sports" that is going to play with your heads some crazy games but nothing to worry about its going to grow up eventually,meanwhile just sit back amd injoy the game after all why did you adapt a "player"
Jun 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport f30
Get the top off there and check the mechanical arm on the dispenser motor. then check that motor. F-30 = dispenser failure.
DUET SPORT SERVICE MANUAL
Sep 24, 2012 | Whirlpool duet Washing Machines
Whirlpool duet sport dryer will not power on no lights nothing
check inside, white fuse should be near air flow . also near themo couplers, take volt meter ,place on continutee, first unplug unit. remove one ,of the two wire's. check to make sure circutt is closed ... if not rplace fuse.
Sep 15, 2012 | Whirlpool 279818 4Way Vent Kit for Duet...
My Whirlpool Duet Sport washing machine won't start. It's like there is no power to it at all. I checked all of the connections and the breaker box and everything is alright.
Please plug a lamp or a radio or a hair dryer into the wall power to verify that indeed power is there. If so then probably your Door Interlock Switch Assembly is bad.
Mar 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet sport will not work
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport. Will not start in any setting.
Get a sledge-hammer to within 2 metres of the washing machine. Then go for the button on the right side "end of cycle" & depress it with your finger for 3 seconds, the control light will come off & I hope you will be able to use your machine.
PS. Remove the sledge-hammer.
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Doesn't start
Is there power in your wall socket? Does any light on the machine come on? Check your washer-plug. The fuse inside the plug could be defective......
Nov 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
