Reboot select proper boot device mdg mini
No disk drive ti install
fraywing
  • 37 Answers
SOURCE: When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
Posted on May 27, 2009
  • 57 Answers
SOURCE: When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Posted on Jun 15, 2009
Testimonial: "Brilliant. Thanks so much. It worked a treat. Much appreciated"
  • 10 Answers
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
Posted on Jun 17, 2009
SOURCE: Can not start HP mini
the hard disk must have gone bad, so when you go to bios go to diagnostics and run a test on hard drive, most probably if it fails , u need to replace the hard disk so call hp and u can replace the same
Posted on Oct 22, 2009
SOURCE: I have an HP 110 Mini
either your hard drive has been damaged or it has been disabled by the bios. Your netbook probably has a solid state hard drive. You need to get your information removed from the drive at this point and get the operating system of your choice installed. For further assistance, you can call us 24/7 at 800-595-3564.
Posted on Jan 18, 2010
G31M-VS reboot and select proper boot device or insert boot media
check whether the hard drive is detecting or not, select the first boot device as hard disk
Feb 02, 2013 | Computers & Internet
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
Tip
Fatal issue: Reboot and Select proper Boot device
<p><b>Issue:</b><br /> <p>Reboot and Select proper Boot device <br />or Insert Boot Media in selected Boot device<br /> <p> <br /> <p> <br /> <img src="matrix12_2.jpg" /> <br /> <p><b>Cause:</b><br /> <p>The boot record could not find a bootable partition so control was passed back to the BIOS. This issue occurs prior to the start of any Windows code. <br /> <p>It can be caused by a power-failure while the disk is in the middle of writing, a virus damaged the entry, a failing disk drive or a serious software bug damaged the partition entry (although Windows typically protects against this). This issue cannot be easily caused by any action you performed, unless you turned off the power without going through Windows shutdown.<br /> <p><b>Workaround:</b><br /> <p>1. If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.<br /> <p>2. It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.<br /> <p>3. If the first bootable drive is missing (disconnected or dead) the BIOS may be attempting to boot from a second disk. Confirm the primary drive is working.<br /><br /> <p> <br /> <p>Hope this will help...Your response is very much appreciated...<br />
on Jan 24, 2011 | Computers & Internet
I dont have boot dissk for my asus f5r laptop what can i do it says reboot and select proper boot device or insert boot media in selected boot device and press a key_
Your ASUS cannot find the hard drive to boot up.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 08, 2012 | ASUS F5RL-B1 (90NM6A233474421L750Y) PC...
My hp mini is showing Reboot and select proper boot device or insert boot media in selected boot device and press a key
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
Dec 21, 2010 | HP Mini 1000 Netbook
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Oct 02, 2010 | HP Mini 110-1037NR Netbook
When I turn it on it says Reboot and select proper boot device or Insert boot media in selected boot device and press a key.
Please verify if you don;t have a floppy disk in your drive. If you don't then you have to verify in BIOS if is selected proper boot device - HDD.
If everything is set then you have problem with your hard disk, must check and install new operating system.
Feb 24, 2010 | E-Machines eMachines Desktop PC
My HP mini shows the "Reoot or select proper boot device or Insert Boot Media in selected Boot device and a press a key" listing. I hit Control/Alt/DEL and get the F9 and F10 options. I have not been able...
select drive "c" as boot device, reboot and if it doesn't boot, then the hdd may be corrupt. if you can get to the hdd recovery setting, use this to reboot to factory spec.
Oct 11, 2009 | HP Mini 1035NR Notebook
Sep 28, 2009 | HP Mini 1035NR Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
