Question about SanDisk Sansa e260 MP3 Player
Pc not showing sansa
I switched to recovery mode. on the sansa screen it says.....
USB cable connected
enter USB2.0 MSD mode
i can't get past this point and the sansa player is not being read by the computer.....please help
    President:
  • SanDisk Expert
  • 650 Answers
You may need to use a labtop which has 2.0usb.. I had to use my labtop first then it updated and my pc recognized it
Posted on Apr 24, 2009
How can I enter de USB 2.0 MSD mode to fix muy sansa e280
To change to MSC, Scroll to settings, scroll down to USB Mode, and choose MSC. You should be good
Apr 05, 2010 | SanDisk Sansa e250 MP3 Player
My recovery mode says "enter USB2.0 MSD mode" what do i do
Hi there.
I can understand your issue. When you say "enter USB2.0 MSD mode"getting into recovery mode. Then i'd say firmware needs to be updated..
Please follow the steps..
There are files in the player that might be corrupted causing the device to freeze and stop responding.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
SOLUTION 2 - Force MSC or Recovery mode then update to the latest firmware.
STEP 1 - Force MSC or go to Recovery mode
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
For e200v2 (Force MSC mode only): Enabling MSC mode
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
STEP 2 - Update to the latest firmware manually, as it is described in Method 2 http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200/r_id/101834.
In case you have any further inquiries, please do not hesitate to contact us!
Jan 04, 2010 | SanDisk Sansa e200 MP3 Player
It say's welcome to recovery mode first
download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Cant get passed recovery mode
this came from another post on fix ya.
For me the solution was this:
After entering the recovery mode (turn off the player, move the hold button to the right, and press the on and rec button, then connecting to the computer).
when the 16 mb folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
My sansa (sandisk e 250) help me pleas
switch to mtp mode or auto in the menu - read your manual for details, and see if you have better luck
Aug 12, 2008 | SanDisk Sansa e250 MP3 Player
USB2.o and MSD mode
You need a memory card.
sincerely, Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 locks up in refresh database during startup
if the computer can find ur sansa(or 16mb format) you should rightcliick and format it. this will delete ur music, videos, etc but it will make ur player usable
Mar 17, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
193 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
