Question about Kenmore Microwave Ovens
Microwave 72180043700 is this a kenmore elite microwave is the magnetron covered under a 5 year warranty
reg501
  • 413 Answers
SOURCE: F9 error
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Posted on Jun 12, 2008
  • 2326 Answers
SOURCE: Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
Posted on Jul 16, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Microwave oven magnetron blown or faulty
You can e-mail the spare parts manager with your model number here: JHB023@seartec.co.za
Posted on Aug 10, 2008
SOURCE: kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Posted on Aug 16, 2008
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
Mine was made july of 2007 so it would be under warrenty then
Typical warranty is 1 year parts and labor and 3 to 5 years on the magnetron tube only. BTW, what's wrong with this unit ??
Oct 09, 2013 | Kenmore 63252 Microwave Oven
GE Spacemaker Microwave Oven STOPPED HEATING
More than likely it's the magnetron and/or diode, chances are it may still be under warranty. Online owners manual states 5 year warranty on magnetron. Part only, service call and installation not included. Diode not covered. They require serial number, and will let you know if it's still under warranty. Installation appears to be simple, UNPLUG MICROWAVE THEN MAKE SURE YOU DISCHARGE CAPACITOR. INJURY OR POSSIBLE DEATH IF NOT DISCHARGED PROPERLY. Google how to install magnetron and discharge capacitor. It will save you approx $ 250 - 300 doing it yourself. Hope this helps. Be Safe
Dec 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microway oven doesn't heat. Everything else works.
Dec 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave will not heat up. there is no buzzing noise.
Dec 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Re: GE Microwave Oven #JVM1870SF001...turns on but will not heat-up item. Can it be the Magnetron and/or Diode is bad?
Comes on but will not heat or cook anything
Dec 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Motor is running, but is not producing heat.
Dec 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No heat from my JVM1640CJ GE microwave. Fan, lights work fine. Unit is less than 5 years old.....I've read some posts on this site - could it be a bad door switch? chip
Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat, already tried replacing fuse. Timer, fan, clock work.
In all probability, the magnetron has died. The magnetron is the part that creates the microwaves that cook your food. Magnetrons are usually covered under a 5- or 10-year warranty and replacing them yourself can be pretty dangerous. I'd suggest you call a technician.
Jul 17, 2009 | GE Microwave Ovens
Microwave
Hi
3 things can fail - the control board, the inverter board, or the magnetron. If the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
If this is not the case then it could be a defective control board, inverter or line voltage too high.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
