Question about Mitsubishi WS-65411 65" Rear Projection Television
Replacement bulbs where do I buy the replacement projection bulb for the WS65411 model tv
ctf1800
  • 4402 Answers
SOURCE: sony Kp 51ws510
Sounds like convergance ic problem to me
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Posted on Dec 18, 2007
ladywinn
  • 5138 Answers
SOURCE: replacing a bulb in a mitsubishi rear projection tv
Are you sure tube is bad and that projecion fluild isnt contamiated if tube lights up but you can not see a picture clearily or at all fliuld is bad remove old fluid replace with new problem FIXED Call Mats for projection fluild 1-800-628-1118
Posted on Sep 18, 2009
eddiepeezy
  • 130 Answers
SOURCE: wd-52526 projection bulb has been replace but
If may be a power supply or ballast issue. The ballast feeds power into the lamp and it may not have enough power, or may not be able to FEED enough power into the lamp after it ignites it. That would account for the dim picture.
Posted on Feb 04, 2010
tvrepairbiz
  • 63 Answers
SOURCE: WD-57731 every 6mos bulb replacement
You need to make sure you have at least 6 to 8 inches of clearance behind the set. You may also need to replace the balast
Posted on Feb 15, 2010
Slinteriors
  • 8617 Answers
SOURCE: Hi I need a replacement bulb for my WS-55411
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Posted on Jul 29, 2010
I have a 65" Mitsubishi
Im, not sure what it is that you are wanting to know about this Model# WS65411,But this TV has 3 Tubes Red,Green,Blue their is No Bulbs Just 3 Picture Tubes.
Encompass Parts Distribution List Parts and PN# for this Model 1-800-638-3328
Visit this website for Part Numbers for R/G/B Tubes.
Apr 12, 2011 | Mitsubishi WS-65411 65" Rear Projection...
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
TV Bulb
Tries websites like Ebay.com Partstore.com to buy bulb replacement and many other parts.
Jul 14, 2010 | InFocus ScreenPlay 61" Rear Projection...
57H81 57 in. Rear Projection Television: My Toshiba model 57h81 is 5+ years old. It just s...
I had the same issue with my 57 in. Mitsubishi. I fixed it by buying a new projection bulb. The Mitsubishi manual indicated this was the fix for my Mitsubishi TV. Be advised that new projection bulbs are not inexpensive. My TV works like new once the projection bulb was replaced.
May 03, 2010 | Televison & Video
Need to replace lamp cant figure out how to take out
on the front of tv set there is a panel that you unscrew to get to the lamp then once you get that done you have to go through the back of tv to remove and yes you can buy the bulb by itself but you have to order it or any tv repair place might have one in stock
May 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Projection bulb replacement
the bulb is usually between 4 to 600 and they are not hard to replace if you take your time with it
Nov 03, 2008 | Zenith Televison & Video
Panasonic 52 projection tv lamp light ?
Sounds like the lamp failed early (not uncommon) and one of the fans has something rubbing on it. Clean the interior and fan filters and replace the bulb (for lamp #TY-LA2005) as follows:
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Jan 10, 2008 | Panasonic PT-52DL10 52" Rear Projection...
Hitachi Rear Projection LCD TV Lamp
Oct 17, 2007 | Hitachi 50V720 Television
Mitsubishi WS-65411 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
