Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I replace the microswitch in my dyson DC04 Zorbster
  • Philip Gaut May 11, 2010
    Do you still want to know, or is it too late now?
Move the flexible hose at the rear out off the way and you will see a small hole that goes through to the on/off switch assembly. Use a small screwdriver through the hole to push the plastic clip away and you can then lift off the on/off button. You will then see a phillips screw that holds the switch assembly/housing to the main unit. Just unscrew and the whole switch unit can be removed.
Posted on May 28, 2009
I have a Dyson DC04 Zorbster. Sometimes there is very little suction & the motor runs slower than normal. If I give it a little shake or push down on the bin (my wife tends to give it a kick) the motor...
Hi David, it's Jack at Dyson.
The issue you're describing sounds very unusual. If the motor seems to be changing speed in use, this could suggest a fault with the motor. DC04 is one of our very oldest machines, and unfortunately due to its age we're no longer able to support it with servicing or spares. However, it would be worth giving our experts a call so we can help confirm if the motor is the cause of the issue - and we can also discuss other the options available to you.
When you have your machine to hand, please give us a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
We'll look forward to speaking to you.
Feb 25, 2015 | Dyson Vacuums
Dyson main switch
Repairing/removing the cable/switch on a Dyson DC04
http://paulroberts69.wordpress.com/2008/01/01/repairingremoving-the-cableswitch-on-a-dyson-dc04-or-similar/
Aug 13, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson dc04 repair manual
Hi there, it's Jack at Dyson.
Our online Support pages for DC04 contain all the information you might need to know to resolve issues with your vacuum in the event of a breakdown: http://www.dyson.co.uk/support/dc04/dc04-brush-control
Although it's an online guide, and is designed to be navigated quickly and easily via your web browser, the pages could also be printed out if you wanted a hard copy.
I hope this helps, but if you'd like any further information or advice, please give our freephone UK Helpline a call on 0800 298 0298.
Jul 24, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
How do I replace the belts on a Dyson DC04 purple
That model has a clutch unit from which the two drive belts are located. It is a technical job to strip that unit down to change the belts, so the easier solution if you have a snapped belt, is to replace the clutch unit (that comes with belts on it). A recycled one represents better value for money, and you can get one here: Dyson DC04 clutch unit.
Nov 07, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Roller does not turn
It sounds as though you need to replace the drive belt. The necessary part is available from http://www.espares.co.uk/dyson/dc04/p/1086/716/4. Fitting it is tricky, but guidance is available from http://www.dysonmedic.com/DC04%20Folder/DC04%20belt%20change.html
Aug 02, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The DC04 Zorbster runs slow, it still picks up but I am worried it will overheat. If I hit it at the front, the motor picks up speed until the next time I start it up. Can you help???
The problem is likely caused by either (a) a broken or worn microswitch operating lever or (b) a faultyt microswitch. With the bin removed, the lever becomes visible just above the filter upon which the base of the bin normally rests.
Replacement of either part necessitates dismantling the appliance. The necessary parts are available from http://www.espares.co.uk/parts/dyson/dc04-zorbster/p/1086/716/4/420621
Jun 23, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
356 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
