Question about Garden
Stihl 028 wb chainsaw tries to start but floods easy and fuel sprays out of carb.
2 Suggested Answers
lindsay836
  • 677 Answers
SOURCE: stihl chainsaw 028 wb will not start it has spark,
Does the saw have a lot of hours on it ? What is the fuel mix you are using, Stihl recommend 40:1
You may need a CARB KIT.
Posted on Feb 05, 2010
Why no power To mY 028 wb chainsaw?
Time to rebuild the carb it sounds like. You didn't give me much to go on, so please give me a few more details.
Oct 12, 2014 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
My stihl 028 super wood boss wont start
is it getting gas?is the fuel filter plugged?does it kick if you drop some fuel into the carb?
Mar 25, 2012 | Garden
Where do I find a operators manuel for Stihl 028 WB?
GO ONLINE TO STIHL AND THEY HAVE A PDF SECTION YOU CAN DOWN LOAD OR PRINT
Dec 31, 2010 | Garden
I have an older stihl 028. The saw starts and idles nice. As soon as you throttle up or put it under load, it bogs out, It also seems a little smokier, Can ya help? I cleaned the carb and jets and...
First check your fuel filter. Its on the end of the pick up tube in the fuel tank. Could be clogged. this is a relatively easy and inexpensive place to start. Make sure the fuel supply isnt pinched anywhere along the way.
Could be a scored cylinder. A scored cylinder is common problem with all makes of chainsaws. If you dont take special care to keep the air filter clean and in perfect working condition, the wood chips and dust will enter the combustion chamber and score the cylinder walls, ruining the rings causing a loss of compression.
The piston could also have been damaged from running to lean of fuel to air mixture causing heat damage to the piston and cylinder.
Hope this was helpful. If so, gimme a thumbs up vote!
Thank You
Oct 08, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
028 wb how do you gap the points with the flywheel removed
You need a cam tool--probably easier to see your Stihl dealer and have them set the points. Good luck!
May 04, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Stihl chainsaw 028 wb will not start it has spark, but always floods, I cleaned the air cleaner
Feb 02, 2010 | Garden
Engine wont run.Stihl 028 chainsaw.
Remove and clean the exhaust port, muffler and spark arrestor screen. Also clean the air filter.
Apr 05, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
