Question about Canon PIXMA MX850 Multifunction Printer
The Canon MX511 printer has a paper jam. Instructions say to turn it on its side and release underside by pushing on a lever. I cannot find the lever....
jackboy
  • 2985 Answers
SOURCE: Canon Pixma Printer
Unload all paper. Examine the feed track for any obstruction- paper fragment - cookie crumbs. Take a vacuum nozzle to it and give it a good suck out. Now feed a heavy weight paper/thin card through. Did it do the trick?
Posted on May 23, 2007
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE: My Canon MX340 printer says
I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Posted on Jan 29, 2012
Canon mx452 paper jam
In the back of the printer there is a lever, but there might be some tape holding it to the printer. Take the tape off, pull the lever and flip the printer on its side. You will then find your paper.
Mar 29, 2013 | Canon Pixma MX452
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has torn...how can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
Paper Jam
Not easy, thats the fuser, normally it is damaged and beyond it causing paper to jam there, no easy fix, cant pull it out without major screwdriver challange...I think thats this one... some fuser s(hot bit that paper exits), are pop out by green release tabs but if I have my models right these are the cheaper version and they fix them to the machine thus ensuring you upgrade..modern world..
Nov 05, 2009 | HP Color LaserJet 2600n Printer
Paper will not feed inti printer
The sensor that detects paper (most cases just a small lever that is pushed up by paper in the tray) isn't engaging. It could be that the paper is not fully inserted, or sometimes in a paper jam, people pull the jammed page out backwards, bending or dislodging the lever. Very common in back-fed printers and shredders.
Sometimes just a visual inspection with a bright light source can show the problem. Be careful not to turn the printer on its side or upside down for any length of time. Inkjet printers usually use a sponge for excess ink discharged during the cleaning process and that can run out and seriously gum up the works, electronics, carpet, and whatever else you really don't want it to.
Aug 24, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
HOW DO i FIND THE PAPER THICKNESS LEVER SO CANON S330 WILL NOT JAM?
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Oct 14, 2008 | Canon S 330 InkJet Printer
Canon PIXMA MX850 Multifunction Printer Logo
89 people viewed this question
old marine
old marine
